Rogue Crusader Posted February 14, 2020 Share Posted February 14, 2020 While I'm loving 90% of the new sculpt I'm not too keen on the extra set of arms so I decided to put it to the knife. I removed the fusion blasters from the secondary arms and transplanted them to her regular arms. The secondary arms were left off and replaced with vector fins made from a 5mm bead and the lower leg wings from a Coldstar. Presto! no more Commander Goro, the rest is stock. Link to comment https://bolterandchainsword.com/topic/361939-2-arm-shadowsun/ Share on other sites More sharing options...
Panzer Posted February 14, 2020 Share Posted February 14, 2020 Nothing won, nothing lost with that conversion in my eyes. If I put the knife to the new model I'd rather go and make a pose where the additional pair of arms makes more sense over completely removing them. Link to comment https://bolterandchainsword.com/topic/361939-2-arm-shadowsun/#findComment-5476891 Share on other sites More sharing options...
Commander Dawnstar Posted February 14, 2020 Share Posted February 14, 2020 I'm definitely going to considering doing this when I have a chance to take in the model in person. I'm still not sure how I feel about the extra arms. Really nice conversion job. You wouldn't even know anything had been changed out unless you knew what to look for. Link to comment https://bolterandchainsword.com/topic/361939-2-arm-shadowsun/#findComment-5476984 Share on other sites More sharing options...
The_Chaplain Posted February 14, 2020 Share Posted February 14, 2020 Can we please get side profile shots? Link to comment https://bolterandchainsword.com/topic/361939-2-arm-shadowsun/#findComment-5477112 Share on other sites More sharing options...
Rogue Crusader Posted February 14, 2020 Author Share Posted February 14, 2020 One of the problems with the secondary arms is that they wouldn't be very functional as situated. Their range of motion overlaps with the standard arms which would make it unable to point the guns straight forward unless the arms were fully extended forward and resting on top of the pilots shoulders which would be rather unwieldy and doesn't make much sense. Going back to the arm configuration grants it better articulation and more important IMO it matches the established visual aesthetic that Tau has. There aren't any other suits with multiple arms and it makes it a bit jarring when placed alongside other stealth suits or ghostkeels. Aside from the extra arms her suit shares a lot of other common elements with the stealth line up, by losing the arms she fits in much better while making the suit a bit more functional looking. But to each their own.Profile & rear pic added above Link to comment https://bolterandchainsword.com/topic/361939-2-arm-shadowsun/#findComment-5477230 Share on other sites More sharing options...
Panzer Posted February 15, 2020 Share Posted February 15, 2020 Well it's a named character. It's okay if she doesn't look exactly like established visual aesthetics of the faction. No other Blood Angel looks anywhere like Mephiston either for example. Link to comment https://bolterandchainsword.com/topic/361939-2-arm-shadowsun/#findComment-5477242 Share on other sites More sharing options...
The_Chaplain Posted February 15, 2020 Share Posted February 15, 2020 You sold me on the two arms Rogue Crusader-- while I will build shadowsun as is, I was also considering getting a second shadowsun model for a CA2018 "create your own" character conversion, and will definitely be going with the two arms for that model. What did you use for the ball/orb portion of the extra thruster you put in the socket? (Nice use of the commander ankle fin bits there by the way) Link to comment https://bolterandchainsword.com/topic/361939-2-arm-shadowsun/#findComment-5477355 Share on other sites More sharing options...
Rogue Crusader Posted February 15, 2020 Author Share Posted February 15, 2020 Just a 5mm plastic bead, a ball bearing would work too. Almost any jewelry or craft stores like hobby lobby should have an assortment of beads or you can get them on amazon. Link to comment https://bolterandchainsword.com/topic/361939-2-arm-shadowsun/#findComment-5477530 Share on other sites More sharing options...
Mithrilforge Posted February 18, 2020 Share Posted February 18, 2020 That looks good, at least it's plastic ...so that's a win in itself Mithril Link to comment https://bolterandchainsword.com/topic/361939-2-arm-shadowsun/#findComment-5478567 Share on other sites More sharing options...
SirVulkan Posted February 20, 2020 Share Posted February 20, 2020 I did this as well and it looks great. Link to comment https://bolterandchainsword.com/topic/361939-2-arm-shadowsun/#findComment-5479783 Share on other sites More sharing options...
Mithrilforge Posted February 21, 2020 Share Posted February 21, 2020 I still want to try and do a heroic pose of her carrying a wounded T'au Fire warrior in her arms carrying them to safety and shooting out to the sides ...It would be very noble and greater good of her Mithril Link to comment https://bolterandchainsword.com/topic/361939-2-arm-shadowsun/#findComment-5480056 Share on other sites More sharing options...
chapter master 454 Posted February 21, 2020 Share Posted February 21, 2020 Surprisingly, I like the 2 arm version better. Just something about it feels better. Likely because the extra arms feel redundant. Link to comment https://bolterandchainsword.com/topic/361939-2-arm-shadowsun/#findComment-5480199 Share on other sites More sharing options...
