-1 invun relic question
Madmonkeyman
How Does the -1 invun relic for ravenwing work. The relic causes units within 3 to have minus one invun.
Example - if my tallon master shoots a 10man unit of storm shield vets , if one is in range of the raven wing bike. Would he just make saves at -1 until the one model dies then the rest of the wounds from the tallon master are taken on the normal invun or would the whole attack for the model be resolved at -1 invun ?
https://bolterandchainsword.com/topic/362023-1-invun-relic-question/
All shots are fired at the same time so the whole unit will be -1 regardless of order of model removing
This ^^^^^^
Also if you are getting within 3" of Characters you'll will probably want to set up a follow up charge with things that can finish the character off because if you don't kill the character in the shooting phase he can use Heroic Intervention to get into your Relic character in your turn.
