3000 DA Ironwing
Looking for inputs to possible improvements. Been using this list for a couple games with good success. Group counts Super Heavy Tanks as tanks.
Ironwing 3000
Legiones Astartes
Praetor: Rite of War (Ironwing Protocol); bolt pistol; Terranic greatsword (master-crafted); melta bombs; iron halo 160
10 Tactical Space Marines: Tactical Sergeant (artificer armour; power fist); 9 Tactical Space Marines 150
Rhino: pintle-mounted multi-melta 50
9 Tactical Support Marines: Tactical Support Sergeant (remove plasma gun; bolter & augury scanner; melta bombs); 8 Tactical Support Marines; plasma guns 285
Contemptor-Cortus Class Dreadnought Talon
Contemptor-Cortus Dreadnought: Dreadnought chainfist (plasma blaster); Dreadnought close combat weapon (plasma blaster); extra armour 190
Contemptor-Cortus Dreadnought: Dreadnought chainfist (graviton gun); Dreadnought close combat weapon (graviton gun); extra armour 180
Contemptor Mortis Dreadnought: 2 Kheres pattern assault cannons 180
Sabre Strike Tank Squadron
Sabre Strike Tank: hull-mounted volkite culverin 80
Deredeo Pattern Dreadnought: Arachnus pattern heavy lascannon battery; torso-mounted twin-linked heavy bolter (molecular acid shells); 4 Boreas air defence missiles 264
Sicaran Arcus Strike Tank: turret-mounted twin Arcus launcher (Skyspear warheads) 220
Vindicator Siege Tank Squadron
Vindicator: hull-mounted laser destroyer array 130
Glaive Super-heavy Special Weapons Tank: Armoured Ceramite 650
2,999 points
https://bolterandchainsword.com/topic/362172-3000-da-ironwing/
  • 2 weeks later...
Talk to your local gaming group, but Superheavies don't have the (Tank) subtype anymore (they did in 6th iirc, but lost it in 7th and still don't have it in the current ruleset), so your list technically needs more tanks. Easiest solution if people won't accept that a unit with Tank in the title should count as a Tank is to make room for another Sabre (3 units of 1). I'd probably do it by cutting out some plasma marines, as I suspect they're all going to be dead before they do anything anyways since they're such an obvious target.
I'm aware that they don't currently have tank, but we are playing as they do. If someone wants to press the issue I just change the Mortis to a Cortus and split the sabres. Not losing much besides the Helical Targeting Array and BS5 on Mortis and Sabres. Already, have two sources of anti-air.  I do agree that the Plasma support squad is a prime target for destruction, but I do like bringing some plasma in a DA list. They would have to be replaced by another source of scoring as 3 is bare min I would like to bring to a game. Was thinking of dropping a melee Dread, swapping the Mortis to a Cortus and I could fit in a 10man Flamer squad for additional scoring.
