Arch69 Posted March 8, 2020 Share Posted March 8, 2020 Hello there I’ve primed macragge blue over my models. The question is do i need to paint macragge blue from the pot over it? I’ve primed my Black Legion with Chaos Black then based coated them with Abaddon Black as the texture and paint looks slightly different. Just wondering if the same is needed for my Ultramarines? Link to comment https://bolterandchainsword.com/topic/362432-primer/ Share on other sites More sharing options...
Tichinde Posted March 8, 2020 Share Posted March 8, 2020 It's useful if you need to use the pot to correct any errors :-) Link to comment https://bolterandchainsword.com/topic/362432-primer/#findComment-5487771 Share on other sites More sharing options...
Arch69 Posted March 8, 2020 Author Share Posted March 8, 2020 It's useful if you need to use the pot to correct any errors :-) So I wouldn’t need to base coat it with a layer of it then. That definitely speeds things up. Link to comment https://bolterandchainsword.com/topic/362432-primer/#findComment-5487813 Share on other sites More sharing options...
Chronotonic Posted March 9, 2020 Share Posted March 9, 2020 Should be close to the same color Link to comment https://bolterandchainsword.com/topic/362432-primer/#findComment-5487836 Share on other sites More sharing options...
mel_danes Posted March 9, 2020 Share Posted March 9, 2020 It's a base coat and primer in one. I use the pot paint to hit the areas I missed with the rattle can. Works great. Just primed +1000 pt's today, got up to 55F in Michigan. Link to comment https://bolterandchainsword.com/topic/362432-primer/#findComment-5487912 Share on other sites More sharing options...
Arch69 Posted March 9, 2020 Author Share Posted March 9, 2020 Should be close to the same color It's a base coat and primer in one. I use the pot paint to hit the areas I missed with the rattle can. Works great. Just primed +1000 pt's today, got up to 55F in Michigan. Thanks for the information. This will help speed up things. Link to comment https://bolterandchainsword.com/topic/362432-primer/#findComment-5487948 Share on other sites More sharing options...
