FormelyKnownAsSmashyPants Posted March 11, 2020 Share Posted March 11, 2020 (edited) Hi all, thinking about buying some Lego technic gears and sprockets for basing but wonder how well primer like chaos black adheres to it? Edited March 11, 2020 by Captain Smashy Pants Link to comment https://bolterandchainsword.com/topic/362490-how-well-does-lego-take-aerosol-primer/ Share on other sites More sharing options...
Astral Arcane Posted March 11, 2020 Share Posted March 11, 2020 (edited) I used to spray paint my Legos all the time as a kid (so they would match color haha) As I recall, the solvents in some spray paint can slightly dissolve the surface of Lego plastic, but not enough to damage the structure. I would recommend getting a spray specifically designed for plastic such as Rust-Oleum plastic paint and of course, experiment first on a sacrificial Lego. You may have more luck if you slightly sand any smooth surfaces with a light grit paper (high number) to promote adhesion. Legos are made from acrylonitrile butadiene styrene. Games Workshop models are a polystyrene formula. The acrylon portion of Legos is what makes them much harder than GW models. Edited March 11, 2020 by Astral Arcane Link to comment https://bolterandchainsword.com/topic/362490-how-well-does-lego-take-aerosol-primer/#findComment-5489581 Share on other sites More sharing options...
Fajita Fan Posted March 11, 2020 Share Posted March 11, 2020 I wouldn't waste GW primer on Legos, I agree you should just get some cheaper hardware store primer that's meant for plastics like lawn furniture. Link to comment https://bolterandchainsword.com/topic/362490-how-well-does-lego-take-aerosol-primer/#findComment-5489657 Share on other sites More sharing options...
Stercus Posted March 11, 2020 Share Posted March 11, 2020 A decent car primer will stick to pretty much any plastic without corroding the detail. In the uk I recommenced the grey one from halfords. It’s genuinely brilliant, and cheaper than the GW equivalent. Link to comment https://bolterandchainsword.com/topic/362490-how-well-does-lego-take-aerosol-primer/#findComment-5489695 Share on other sites More sharing options...
