hermanista Posted March 15, 2020 Share Posted March 15, 2020 Evening! So I've got some specific threads in certain subforums, but thought I'd group a load of stuff together. Starting on this little toy - A Valder tank hunter vandalised, defiled and hot wired by some naughty Genestealer Juves... Still heavily WIP, but it's getting closer to finish, another week or two maybe with luck. The last four pictures were taken this evening after adding the decals and luckily show off the micro-weathering much better. Those cracks will need a second highlight at some point... What do folks think? Chris Link to comment https://bolterandchainsword.com/topic/362588-hermanistas-eclectic-menagerie-random-projects/ Share on other sites More sharing options...
Debauchery101 Posted March 16, 2020 Share Posted March 16, 2020 Some of it looks like when I spider my airbrush cuz I'm still learning lol I feel your ability to do the cracks is great. I also think it may be a bit overdone and slightly off on the origination. Cracks and chips in powder coated paint usually originate from impacts that go to the metal, weld seams and where there are penetrations in metal to install bolts. Have you tried using chipping mediums? For the edges that show metal I like to chip to primer then use metal on top and then use highlights on the edges of the main color that was chipped. It's like a 4 color look to the weathering Also do you varnish at all before weathering? I find it really helps to use a varnish pre weathering. Washes and painted effects can be controlled and tweaked on a satin or gloss varnish. Link to comment https://bolterandchainsword.com/topic/362588-hermanistas-eclectic-menagerie-random-projects/#findComment-5491556 Share on other sites More sharing options...
Debauchery101 Posted March 16, 2020 Share Posted March 16, 2020 Check this dude out. Hes really good at showing techniques step by step. https://youtu.be/ku4comhKHJM https://youtu.be/rP0NenvyWNw Link to comment https://bolterandchainsword.com/topic/362588-hermanistas-eclectic-menagerie-random-projects/#findComment-5491559 Share on other sites More sharing options...
