IF 2k / 3k / 4k
So I had a list I was pretty much set on when I started collecting fists. This has by now somewhat permutated so I wanted to introduce my ideas for what I am working towards right now:
2k
++ Crusade (Legiones Astartes: Age of Darkness Army List) [2,000pts] ++
+ HQ +
Sigismund [230pts]
+ Elites +
Apothecarion Detachment [115pts]
. Apothecary, Legion: Artificer Armour, Power Sword
. Apothecary, Legion: Augury Scanner, None (Infantry, Power Armour)
. . Chainsword or Combat Blade: Chainswords/Combat Blades
Contemptor Dreadnought Talon [195pts]
. Contemptor Dreadnought, Legion: Extra Armour, Kheres Pattern Assault Cannon, Twin-linked Heavy Bolter
+ Troops +
Tactical Squad, Legion [160pts]: Bolters, 9x Tactical Space Marines, Legion
. Rhino Armoured Carrier, Legion
. Tactical Sergeant, Legion: Bolter
Tactical Support Squad, Legion Plasma Gun [245pts]: Plasma gun
. Sergeant, Legion: Artificer Armour, Bolt Pistol, Plasma Gun
. 6x Space Marines, Legion: 6x Bolt Pistols, 6x Frag and Krak Grenades, 6x Power Armour
Templar Brethren , Compulsory [325pts]: 7x Combat Shield, Melta Bombs, 7x Templar Brethren
. Chapter Champion: Combat Shield, Solarite Power Gauntlet
+ Heavy Support +
Land Raider Battle Squadron, Legion [535pts]
. Land Raider Phobos: Armoured Ceramite, Auxiliary Drive, Dozer Blade, Extra Armour
. Land Raider Proteus: Armoured Ceramite, Auxiliary Drive, Dozer Blade, Explorator Augury Web, Extra Armour
+ Allegiance +
Legion and Allegiance: VII: Imperial Fists, Loyalist
Rite of War: Primarch's Chosen
+ Use Playtest Rules +
Use Playtest Rules: Playtest Rules On
++ Total: [2,000pts] ++
3k
++ Crusade (Legiones Astartes: Age of Darkness Army List) [3,000pts] ++
+ HQ +
Sigismund [230pts]
+ Elites +
+ Troops +
Terminator Squad, Legion , Compulsory [895pts]
. Cataphractii Pattern Terminator Armour
. Spartan Assault Tank, Legion: Armoured Ceramite, Auxiliary Drive, Dozer Blade, Flare Shield, Quad Lascannon Sponsons x2, Twin-linked Heavy Bolter
. Terminator Sergeant, Legion: Chainfist, Grenade Harness, Vigil Pattern Storm Shield
. Terminators, Legion: Chainfist, Vigil Pattern Storm Shield
. Terminators, Legion: Power Fist, Vigil Pattern Storm Shield
. Terminators, Legion: Iliastus Pattern Assault Cannon, Power Fist
Veteran Tactical Squad, Legion , Compulsory [265pts]: 9x Bolt Pistol, 7x Bolter, 9x Chainswords/Combat Blades, Missile Launcher and Suspensor Web, Missile Launcher and Suspensor Web, 9x Veteran Space Marines, Legion, Veteran Tactics: Machine Killers, Vexilla, Legion
. Veteran Sergeant, Legion: Artificer Armour, Bolt Pistol, Bolter
+ Heavy Support +
+ Allegiance +
++ Total: [3,000pts] ++
Created with BattleScribe
4k
++ Crusade (Legiones Astartes: Age of Darkness Army List) [4,000pts] ++
+ HQ +
Rogal Dorn [385pts]
Sigismund [230pts]
+ Elites +
Techmarine Covenant [35pts]
. Techmarine, Legion: Power Axe, Servo-arm
+ Troops +
Veteran Tactical Squad, Legion , Compulsory [280pts]: 9x Bolt Pistol, 7x Bolter, 9x Chainswords/Combat Blades, Missile Launcher and Suspensor Web, Missile Launcher and Suspensor Web, 9x Veteran Space Marines, Legion, Veteran Tactics: Machine Killers, Vexilla, Legion
. Veteran Sergeant, Legion: Artificer Armour, Bolt Pistol, Bolter, Power Fist
+ Heavy Support +
+ Allegiance +
+ Lords of War +
Falchion Super-heavy Tank Destroyer, Legion [565pts]: Armoured Ceramite, Quad Lascannon Sponsons x2, Space Marine Legion Crew, Twin-linked Heavy Bolters
++ Total: [4,000pts] ++
Maybe I should also say something about how this kist is supposed to work:
So the idea is that Templars and Terminators can punch resiliant enemies off objectives or counter enemy death stars. And also cap the points then. The support squad can outflank to hopefully get into the side of enemy armour together with their ride.
Veterans leave some room to experiment/get changed to fit the enemy.
Apothecaries join the templars and the plasma squad.
Since I face ordo reductor und iron fire iron warriors a lot I hope to weather some shooting ny putting my stuff in transports. I could always loose some armoured ceramite to give both contemptors twin lascannons. Currently they are for AA duty and for killing infantry.
https://bolterandchainsword.com/topic/362800-if-2k-3k-4k/
  • 2 weeks later...
Pretty solid lists, I'd say!
I'm a bit concerned about your lack of anti-air, though, but maybe you don't face flyers that much in your opponents armies? You say the contemptors are for AA duty, but why not make them Mortis?
My biggest conundrum though is why you pick Primarch's Chosen as your Rite of War in your first two lists, while not taking Dorn?
Otherwise, nice lists! Would be fun to play against something like this!
https://bolterandchainsword.com/topic/362800-if-2k-3k-4k/#findComment-5501024
You are completely correct, I wanted two mortis contemptors. Just pressed the wrong buttons in battlescribe.
I took primarchs chosen to have the terminators be troops and thus scoring. But I guess that only works if dorn is in the army?
Also: with mortis contemptors being 10 points cheaper I could also give them lascannons but that costs me most of the anti infantry shooting I have.
https://bolterandchainsword.com/topic/362800-if-2k-3k-4k/#findComment-5501581
I could propably cut out the armoured ceramite I think. I play mechanicum and iron warriors a lot and both tend not to bring tons of melta. Or take some equipment away from the apothecaries. I want the one wholl go with the templard to keep his artificer armour though. Dont want him to get picked off in duels since IF ICs habe to Challenge.
I got havoc launchers for both dreads built and painted.
https://bolterandchainsword.com/topic/362800-if-2k-3k-4k/#findComment-5502670
Yeah so thats the rite of war cut for 2k points, because tacticals and templars will be compulsory troops with sigismund.
For 3k I'll have to do pride to fill out my troops choices with vets and for 4k well its gonna be primarchs chosen then. Or i make the vets into normal tacticals and buy some more upgrades for the rest of the squads.
Thanks you guys.
I have changed the list around a bit to give the havoc launchers to the dreads. I lost the vexillas and some power swords on apothecaries and sgts.
https://bolterandchainsword.com/topic/362800-if-2k-3k-4k/#findComment-5503512
