Basilisk and Hydra
If you mean pointing straight forwards (parallel to the tank/ground) then the Hydra can, the Basilisk's Earthshaker rests at a slight angle - near enough to be direct fire though :) They are rotating guns so you can have them point at any of their angles if you don't glue them in place :tu:
