Dindrenzi Posted April 2, 2020 Share Posted April 2, 2020 Hey folks, Wondering if anyone has used a brush in superglue? Looking for precision application for magnetising so I don't stick the magnets together, so only need a tiny amount of glue Link to comment https://bolterandchainsword.com/topic/362971-anyone-used-a-brush-in-superglue/ Share on other sites More sharing options...
Firedrake Cordova Posted April 2, 2020 Share Posted April 2, 2020 Never seen a brush-on one. I've seen scale modellers when gluing small components (e.g. undercarriage on a jet) decanting a small dot onto something (top of a tin can, etc), and then using the tip of a toothpick to take a small dot and apply it to the item..? (they're probably using one of the thinner CA glues, too) tychobi 1 Back to top Link to comment https://bolterandchainsword.com/topic/362971-anyone-used-a-brush-in-superglue/#findComment-5500213 Share on other sites More sharing options...
infyrana Posted April 2, 2020 Share Posted April 2, 2020 Recently tried the gorilla glue with a brush. Personally I found it smells worse and I spent longer with the lid off trying to wipe excess glue from the brush before I could apply it (the brush isn't tiny either). It's actually gone thick quite quickly like it's drying up, so I'm preferring the normal pots of loctite superglue and use paper towel and toothpicks to manage it. I just drop a bit in the magnet hole, soak up excess with a corner tip of paper towel, pop in the magnet and wipe the spill with the paper again. Link to comment https://bolterandchainsword.com/topic/362971-anyone-used-a-brush-in-superglue/#findComment-5500215 Share on other sites More sharing options...
Dindrenzi Posted April 2, 2020 Author Share Posted April 2, 2020 Cheers guys. I used the loctite with a brush and had similar terrible results, the brush was far too big to be of any use. I may try a small, synthetic brush in my glue bottle and failing that I'll try the toothpick approach Link to comment https://bolterandchainsword.com/topic/362971-anyone-used-a-brush-in-superglue/#findComment-5500254 Share on other sites More sharing options...
Khornate individual Posted April 2, 2020 Share Posted April 2, 2020 lol, yeah you'd be better off using toothpicks. You would be going through paint brushes like crazy unless one dries to the shape you need and be used over and over. If the point of the tooth pick is too small, clip it off and or cut it so it slants giving an area to kind of scoop up a little glue on Link to comment https://bolterandchainsword.com/topic/362971-anyone-used-a-brush-in-superglue/#findComment-5500317 Share on other sites More sharing options...
jokaero weaponsmith Posted April 2, 2020 Share Posted April 2, 2020 I find for applying super glue I use a needle. If you cut the needle using pliers so that the eye of the needle is open like a u shape you can dip it in the super glue and then apply it. If the needle eye blocks up hold it over a flame and the glue burns off, just keep the glue itself away from the open flame. The bigger the eye of the needle the more glue you can apply. I used this technique for applying rivets and other small details on my models. Venerable Jazzman 1 Back to top Link to comment https://bolterandchainsword.com/topic/362971-anyone-used-a-brush-in-superglue/#findComment-5500370 Share on other sites More sharing options...
infyrana Posted April 2, 2020 Share Posted April 2, 2020 Careful though - if you cut a hardened needle - cover it and shield your face etc or you will lose an eye to flying metal debris! Still, the toothpick is easiest, easily replaced and you can shave it into smaller sizes, or it will naturally get fatter with more added glue layers. Doing so with a brush that's stored outside of the glue pot will just make for a hardened brush (ie might as well use the toothpick). Link to comment https://bolterandchainsword.com/topic/362971-anyone-used-a-brush-in-superglue/#findComment-5500445 Share on other sites More sharing options...
Bung Posted April 3, 2020 Share Posted April 3, 2020 Careful though - if you cut a hardened needle - cover it and shield your face etc or you will lose an eye to flying metal debris! Still, the toothpick is easiest, easily replaced and you can shave it into smaller sizes, or it will naturally get fatter with more added glue layers. Doing so with a brush that's stored outside of the glue pot will just make for a hardened brush (ie might as well use the toothpick). AK Interaktive sells Brass toothpicks which can be cleaned easily. There are superglue applicators sold as scale modelling tools. Link to comment https://bolterandchainsword.com/topic/362971-anyone-used-a-brush-in-superglue/#findComment-5500575 Share on other sites More sharing options...
MaliGn Posted April 3, 2020 Share Posted April 3, 2020 I use the gorilla glue bottle as while it is good it is easily the best glue I've ever used, it does have a nozzle option as well as the brush so it's theoretically best of both worlds... As mentioned above it can get quite gloopy as it gets used. Link to comment https://bolterandchainsword.com/topic/362971-anyone-used-a-brush-in-superglue/#findComment-5500644 Share on other sites More sharing options...
Xenith Posted April 3, 2020 Share Posted April 3, 2020 Hey folks, Wondering if anyone has used a brush in superglue? Looking for precision application for magnetising so I don't stick the magnets together, so only need a tiny amount of glue All GW glues used to be brush on, and it was far superior. No splodging. I couldnt name you a quality brush on brand now, though, but keen to test out if you find one. Link to comment https://bolterandchainsword.com/topic/362971-anyone-used-a-brush-in-superglue/#findComment-5500667 Share on other sites More sharing options...
Fajita Fan Posted April 3, 2020 Share Posted April 3, 2020 I use a Loctite precision pen for gluing magnets down to 3mm wide. https://www.amazon.com/Loctite-Super-Precision-4-Gram-2112877/dp/B072Q49T91/ref=mp_s_a_1_4?dchild=1&keywords=loctite+precision+pen&qid=1585921080&sprefix=loctite+pre&sr=8-4 It’s gel, not thin, so I can put down a tiny bead then I apply the magnet with a toothpick and a tiny dot of blue tack on there. I’ve been able to glue the tiny arms of AT scale knights and little turrets this way. After it’s dry I can go back and drip thin superglue around the magnet to really seal it in there if I’m nervous about the bond. A couple of tips here. I always blot the tip of my superglue applicator on a piece of wax paper or shiny retail packaging cardboard - this helps prevent crust forming - and I cap my glue between joins. Also with respect to magnetizing you rarely need super strong N52 grade magnets for swapping weapons or magnetizing bases to sheet metal. You just need enough for them stick, more powerful magnets means more grabbing your models to pull them apart and a risk to your paint job (had to repaint some guys and I actually broke a waist with magnetized bases). Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/362971-anyone-used-a-brush-in-superglue/#findComment-5500738 Share on other sites More sharing options...
Disruptor_fe404 Posted April 4, 2020 Share Posted April 4, 2020 I use the Selleys QuickFix stuff that the hardware store sells for household repairs. It's still cyanoacrylate, and comes with a brush that lives in the bottle. Link to comment https://bolterandchainsword.com/topic/362971-anyone-used-a-brush-in-superglue/#findComment-5501115 Share on other sites More sharing options...
