Token Posted April 17, 2020 Share Posted April 17, 2020 Wulfen are cool, and i liked the old ones with power armor that was kinda damaged, the new ones dont look all that good, i think. How big are they? Could you kitbash with Primaris to give them a diffirent look? Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/ Share on other sites More sharing options...
RikuEru Posted April 17, 2020 Share Posted April 17, 2020 (edited) The Weapons have perfect Primaris suizable size. Edited April 17, 2020 by RikuEru N1SB, Zephaniah Adriyen and Tichinde 3 Back to top Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/#findComment-5507746 Share on other sites More sharing options...
Token Posted April 17, 2020 Author Share Posted April 17, 2020 Cool models. Size seems good. You play them counts as? Any specific fluff for them? Just big dudes with cool weapons? Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/#findComment-5507750 Share on other sites More sharing options...
dice4thedicegod Posted April 17, 2020 Share Posted April 17, 2020 I use these as Wulfen: (Reiver/wulfen mix) N1SB and Noserenda 2 Back to top Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/#findComment-5507760 Share on other sites More sharing options...
Token Posted April 17, 2020 Author Share Posted April 17, 2020 Cool wulfens. The backpacks that come with the Wulfen box, they dont fit all that well? Another thing, would be nice of you, how do you paint those pouches, what colors? Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/#findComment-5507768 Share on other sites More sharing options...
dice4thedicegod Posted April 17, 2020 Share Posted April 17, 2020 From memory, I think I did the pouches using Americana acrylics (budget paints): darker base of “burnt umbar “ followed by highlighting with “khaki tan”. I was just using the backpacks I had (I’d scavenged various bits off eBay, so didn’t have a full wulfen kit) Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/#findComment-5507775 Share on other sites More sharing options...
Token Posted April 17, 2020 Author Share Posted April 17, 2020 Ah, i dont think i have those colors, thanks anyways. Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/#findComment-5507779 Share on other sites More sharing options...
ranulf the revenant Posted April 17, 2020 Share Posted April 17, 2020 The primaris conversion workd quite well . I went a different route and used the goliath gangers from Necromunda and 3rd party parts (Kromlech, Spellcrow, Puppetswar).The result is more of an old marine size though... dice4thedicegod, Ryltar Thamior, Oshikai and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/#findComment-5507787 Share on other sites More sharing options...
PeteySödes Posted April 17, 2020 Share Posted April 17, 2020 I need to make another unit... Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/#findComment-5507791 Share on other sites More sharing options...
Oshikai Posted April 17, 2020 Share Posted April 17, 2020 The primaris conversion workd quite well . I went a different route and used the goliath gangers from Necromunda and 3rd party parts (Kromlech, Spellcrow, Puppetswar). The result is more of an old marine size though... Uuuh...I quiet like that idea! Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/#findComment-5507825 Share on other sites More sharing options...
Valerian Posted April 17, 2020 Share Posted April 17, 2020 The Weapons have perfect Primaris suizable size. I expect that is no accident. GW already knew they were transitioning to Primaris when the latest Wulfen kit was released, and likely already had a pretty good start on the new model line. Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/#findComment-5507871 Share on other sites More sharing options...
Karhedron Posted April 17, 2020 Share Posted April 17, 2020 I am planning to mix in some Reivers to give about 8 models. That should dilute the wulfiness a bit. Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/#findComment-5507891 Share on other sites More sharing options...
ranulf the revenant Posted April 17, 2020 Share Posted April 17, 2020 The primaris conversion workd quite well . I went a different route and used the goliath gangers from Necromunda and 3rd party parts (Kromlech, Spellcrow, Puppetswar). The result is more of an old marine size though... ___________________________________________________________________________________________________________________________________________________________________ Uuuh...I quite like that idea! Thank you... None of them is painted yet though... Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/#findComment-5507899 Share on other sites More sharing options...
mactire Posted April 17, 2020 Share Posted April 17, 2020 Going with the Reiver mix as well, can't stand the Wulfen feet so this is a way around it I hope. I'm working on one at the moment where I'm cutting the Wulfen off at the knees and then adding the boots to hopefully get a running posture. Will post a pic when done. Graymane, Valerian and Karhedron 3 Back to top Link to comment https://bolterandchainsword.com/topic/363264-alternate-wulfen-models/#findComment-5507983 Share on other sites More sharing options...
