BadgersinHills Posted April 21, 2020 Share Posted April 21, 2020 Hey all, Modelling question for you all. Planning a conversion of the Young Kin and was wondering if the Intercessor legs without the greaves are compatible with Ragnar's greaves. Thanks! :) Link to comment https://bolterandchainsword.com/topic/363369-ragnar-and-intercessors-model-question/ Share on other sites More sharing options...
Bryan Blaire Posted April 21, 2020 Share Posted April 21, 2020 Something you are going to run into difficulty with is the angle of the greave to the upper foot plate - you may need to slice between them if the leg you are putting the material onto doesn't have the same angle of foot to lower leg/shin & calf area for the bit numbered 5 on his sprue. For the bit numbered 3, you're going to have to put it onto a leg that already has the upper foot plate, or find a way to put one on, since that bit doesn't have one attached. Otherwise they appear to be the same width - depth could also possibly be an issue, but that I can't speak to, I don't have a Ragnar to check since they didn't release him separately and the images don't really let you determine it. BadgersinHills 1 Back to top Link to comment https://bolterandchainsword.com/topic/363369-ragnar-and-intercessors-model-question/#findComment-5510262 Share on other sites More sharing options...
BadgersinHills Posted April 24, 2020 Author Share Posted April 24, 2020 Thanks, Bryan! Greenstuffing won't be a problem if things don't match, now, just to get the dang model haha. Bryan Blaire 1 Back to top Link to comment https://bolterandchainsword.com/topic/363369-ragnar-and-intercessors-model-question/#findComment-5511576 Share on other sites More sharing options...
Bryan Blaire Posted April 24, 2020 Share Posted April 24, 2020 I’m going to be waiting on the eventual separate release - although I really could use his Belt of Russ for another conversion. :lol: BadgersinHills 1 Back to top Link to comment https://bolterandchainsword.com/topic/363369-ragnar-and-intercessors-model-question/#findComment-5511845 Share on other sites More sharing options...
BadgersinHills Posted April 25, 2020 Author Share Posted April 25, 2020 I’m going to be waiting on the eventual separate release - although I really could use his Belt of Russ for another conversion. I'm not looking forward to his cost, though. You really do pay for those 10 attacks. Looking forward to see what you do with the Belt of Russ! Ragnar has so many nice parts for converting great characters. Link to comment https://bolterandchainsword.com/topic/363369-ragnar-and-intercessors-model-question/#findComment-5512116 Share on other sites More sharing options...
Karack Blackstone Posted April 25, 2020 Share Posted April 25, 2020 I'm likely to need two Ragnar models. One for Ragnar. Second for conversion bits, at this rate. Bryan Blaire and BadgersinHills 2 Back to top Link to comment https://bolterandchainsword.com/topic/363369-ragnar-and-intercessors-model-question/#findComment-5512271 Share on other sites More sharing options...
