Diagramdude Posted April 22, 2020 Share Posted April 22, 2020 "on a 4+ you can return one destroyed model from that unit to the battlefield with 1 wound remaining, placing it within 3" of this model and in unit coherency." If you Upon Wings of Fire a damaged jump pack unit 9" away from the enemy and have your Sanguinary Priest in the right position, you could resurrect a casualty and place that model within 2" coherency but as close as possible to the enemy charge target. From the other side of the resurrected model's base you would be within 6" of the enemy unit for a much easier charge! Indefragable, librisrouge, SnorriSnorrison and 7 others 10 Back to top Link to comment Share on other sites More sharing options...
Indefragable Posted April 22, 2020 Share Posted April 22, 2020 ThatOneMarshal, Karhedron, Morticon and 6 others 9 Back to top Link to comment Share on other sites More sharing options...
Blindhamster Posted April 22, 2020 Share Posted April 22, 2020 thanks Indy, you made me giggle with the gif Link to comment Share on other sites More sharing options...
Morticon Posted April 23, 2020 Share Posted April 23, 2020 ACHIEVEMENT: UNLOCKED Gooooood call, buddy!!!! Diagramdude and Indefragable 2 Back to top Link to comment Share on other sites More sharing options...
Hintzy Posted April 23, 2020 Share Posted April 23, 2020 Yeah, this is a real good catch. I can't think of anything offhand that might disallow it. I know Chaos Demons can accomplish some similar, much more easily, when Horrors split as a result of overwatch. That's been allowed in tournaments at the highest level so this should be totally good to go, albeit a bit more challenging to accomplish I think. Diagramdude 1 Back to top Link to comment Share on other sites More sharing options...
ThatOneMarshal Posted April 23, 2020 Share Posted April 23, 2020 Well now I gotta find a way to get a sanguinary priest back into my list. Link to comment Share on other sites More sharing options...
Majkhel Posted April 23, 2020 Share Posted April 23, 2020 A real gem, brother! I applaud you! Link to comment Share on other sites More sharing options...
SnorriSnorrison Posted April 23, 2020 Share Posted April 23, 2020 This sounds sooo cheesy, brother :D But you know, if the stars align and it’s technically legal, why not? Just don’t do it in a friendly game. ^^ Link to comment Share on other sites More sharing options...
Xenith Posted April 23, 2020 Share Posted April 23, 2020 *Imagines the priest flying about with his dying brother in tow* Good find, though. It doesn't even have to be that way, move the jumpers into position then UWoF the priest to them? Link to comment Share on other sites More sharing options...
Majkhel Posted April 23, 2020 Share Posted April 23, 2020 "On your feet, brother! Duty eternal! Go get 'em!" *shoves the now not-so-wounded marine towards the enemy* Brilliant! :D Spyros and SnorriSnorrison 2 Back to top Link to comment Share on other sites More sharing options...
SnorriSnorrison Posted April 23, 2020 Share Posted April 23, 2020 That...that actually kinda makes sense. :D Good thing I always try to squeeze in a Sanguinary Priest with the Icon of the Angel anyway :) Karhedron 1 Back to top Link to comment Share on other sites More sharing options...
Xenith Posted April 23, 2020 Share Posted April 23, 2020 *Starts looking for Sanguinary Priest Bitz* This can also help out slow chargers, right? Imagine a unit of cataphractii or aggressors that might be 10" away from the target, resurrect a guy and suddenly youre 88mm closer... Karhedron 1 Back to top Link to comment Share on other sites More sharing options...
Diagramdude Posted April 23, 2020 Author Share Posted April 23, 2020 This trick is a bit handicapped when using two wound models like Sanguinary Guard or Terminators because the ressurected model will have only 1 wound remaining and will be the first removed by overwatch. Then you're back where you started. Link to comment Share on other sites More sharing options...
SnorriSnorrison Posted April 23, 2020 Share Posted April 23, 2020 This trick is a bit handicapped when using two wound models like Sanguinary Guard or Terminators because the ressurected model will have only 1 wound remaining and will be the first removed by overwatch. Then you're back where you started. Not sure, but wasn’t that only in 6th or 7th edition? I thought you could remove from where you wanted when shot at. Link to comment Share on other sites More sharing options...
Diagramdude Posted April 23, 2020 Author Share Posted April 23, 2020 If your unit has any wounded models you have to allocate wounds to them first before any full models. This prevents people from spreading wounds around their multi-wound models before finally removing one. Karhedron and SnorriSnorrison 2 Back to top Link to comment Share on other sites More sharing options...
Djangomatic82 Posted April 23, 2020 Share Posted April 23, 2020 If your going up against something with a lot of shots, the Chalice Overflowing strat might solve that issue, if you have the CP remaining. Link to comment Share on other sites More sharing options...
Montoya Posted April 24, 2020 Share Posted April 24, 2020 would still work with death company though Link to comment Share on other sites More sharing options...
SnorriSnorrison Posted April 24, 2020 Share Posted April 24, 2020 If your unit has any wounded models you have to allocate wounds to them first before any full models. This prevents people from spreading wounds around their multi-wound models before finally removing one. Ah yes, good call. Had forgotten about that... Still works with VanVets and DC! Link to comment Share on other sites More sharing options...
Karhedron Posted April 24, 2020 Share Posted April 24, 2020 This trick is a bit handicapped when using two wound models like Sanguinary Guard or Terminators because the ressurected model will have only 1 wound remaining and will be the first removed by overwatch. Then you're back where you started. A risk to be sure but at least both those units have a 2+ save to reduce the risk of casualties from overwatch. Link to comment Share on other sites More sharing options...
Xenith Posted April 24, 2020 Share Posted April 24, 2020 (edited) This trick is a bit handicapped when using two wound models like Sanguinary Guard or Terminators because the ressurected model will have only 1 wound remaining and will be the first removed by overwatch. Then you're back where you started. Indeed, This gives a decent advantage to Sorrow's Genesis, which resurrects at 3W. Makes up for the lack of +1" to charge distance for FT's I guess, but a nice boost to my planned FT Aggressor blob. Edited April 24, 2020 by Xenith Diagramdude 1 Back to top Link to comment Share on other sites More sharing options...
Diagramdude Posted April 25, 2020 Author Share Posted April 25, 2020 Yeah Xenith, Sorrow's Genesis is amazing for this especially because it works on a 2+. With the 4+ you're potentially burning an extra CP on the reroll, which could fail and then force you to use Descent of Angels for the 9" charge. Now you're out 5 CP instead of 4 for the normal UWOF/DOA or just 2 if the resurrection had worked. Link to comment Share on other sites More sharing options...
