Khulu Posted May 2, 2020 Share Posted May 2, 2020 I don't know if this is feasible or not, given the existing framework the board is built out of. But, would it be possible to show the post you are reporting while writing the report (like when you are posting a reply and not using the quick reply feature, it shows the posts underneath)? It'd make it easier sometimes to refer to the specific issue in a post. Link to comment https://bolterandchainsword.com/topic/363617-reporting-posts/ Share on other sites More sharing options...
WarriorFish Posted May 2, 2020 Share Posted May 2, 2020 Unfortunately not with the current software, the simplest solution is to open the Report button's link in a new tab so you can reference it if needed :tu: Link to comment https://bolterandchainsword.com/topic/363617-reporting-posts/#findComment-5515790 Share on other sites More sharing options...
Khulu Posted May 3, 2020 Author Share Posted May 3, 2020 Figures! Thanks for the info! Link to comment https://bolterandchainsword.com/topic/363617-reporting-posts/#findComment-5516093 Share on other sites More sharing options...
