CCE1981 Posted May 5, 2020 Share Posted May 5, 2020 I have a Successor Space Marine Chapter, that I use to play around with lists from the different codices. I have a Space Wolves list that includes Wolfen. I need ideas to make a counts as Wolfen unit that looks like an Elite Primaris unit. Looking to get some possible ideas to make them stand out and nobody will question them. Chapter name Tempestus Griffins if that helps. Thanks!!! Link to comment https://bolterandchainsword.com/topic/363677-counts-as-wulfen-alternative-ideas/ Share on other sites More sharing options...
dice4thedicegod Posted May 5, 2020 Share Posted May 5, 2020 I mixed wulfen and reiver kits Link to comment https://bolterandchainsword.com/topic/363677-counts-as-wulfen-alternative-ideas/#findComment-5516869 Share on other sites More sharing options...
ranulf the revenant Posted May 5, 2020 Share Posted May 5, 2020 There are some examples here:http://www.bolterandchainsword.com/topic/363264-alternate-wulfen-models/?hl=%2Bwulfen&do=findComment&comment=5507983But I'm not sure if that's what you want... Maybe give us some info about the fluff you came up with I need ideas to make a counts as Wolfen unit that looks like an Elite Primaris unit. I mean, it depends what "elite" means for you. Maybe something like a Primaris version of assasins? If that's the case, you could use reiver bodies and fancy 3rd party helmets?I don't know... something like this?https://puppetswar.eu/models-and-bits-50/all-bits/heads/super-ninja-heads.html(or even this, if you're up for a tongue-in-cheek-look: https://puppetswar.eu/models-and-bits-50/all-bits/heads/heroes-team-heads.html) Link to comment https://bolterandchainsword.com/topic/363677-counts-as-wulfen-alternative-ideas/#findComment-5516944 Share on other sites More sharing options...
CCE1981 Posted May 5, 2020 Author Share Posted May 5, 2020 These are my Veteran Intercessors that I currently use. I am liking the close combat Reivers. Maybe I can use the Sagitarum Heads and arms to Reivers, and add Lightning claws, Great Axes, and Thunder Hammer and Storm Shields to the arms. It would certainly make them look interesting. Link to comment https://bolterandchainsword.com/topic/363677-counts-as-wulfen-alternative-ideas/#findComment-5516968 Share on other sites More sharing options...
ranulf the revenant Posted May 5, 2020 Share Posted May 5, 2020 Seeing that your guys have a somewhat knightly look, you could obviously look into stormcast models as well. Marvellous models btw... Link to comment https://bolterandchainsword.com/topic/363677-counts-as-wulfen-alternative-ideas/#findComment-5517004 Share on other sites More sharing options...
CCE1981 Posted May 5, 2020 Author Share Posted May 5, 2020 Thanks! I am thinking of using Reivers, and give them the ForgeWorld Saggitarrum heads and arms and using Marine close combat weapons. Link to comment https://bolterandchainsword.com/topic/363677-counts-as-wulfen-alternative-ideas/#findComment-5517289 Share on other sites More sharing options...
CCE1981 Posted May 6, 2020 Author Share Posted May 6, 2020 My Quick write up for my Chapter Link to comment https://bolterandchainsword.com/topic/363677-counts-as-wulfen-alternative-ideas/#findComment-5517672 Share on other sites More sharing options...
