plastic_slug Posted May 10, 2020 Share Posted May 10, 2020 I finished the last two Aeronautica models I had in my stash, these Grot Bommers. Came out okay, except for the stands. It seems the mounting hole for the stand was too large on these. I had to glue the Bommers to the stands, otherwise they were easily knocked off. Not a tight fit at all, like the other models I’ve built so far. Fajita Fan and duz_ 2 Back to top Link to comment https://bolterandchainsword.com/topic/363802-grot-bommers-completedissue/ Share on other sites More sharing options...
Fajita Fan Posted May 11, 2020 Share Posted May 11, 2020 If you want them to come off the stands you could just use thin magnets, that's what I've done on flying stand for things like Landspeeders. If/when I finish my AI stuff I'll probably just slap 1mm thick magnets on there. Those look great, though! Link to comment https://bolterandchainsword.com/topic/363802-grot-bommers-completedissue/#findComment-5519997 Share on other sites More sharing options...
plastic_slug Posted May 11, 2020 Author Share Posted May 11, 2020 Thanks. I’m not too broken up about the gluing them to the flight stands. I was likely going to leave mine on them and not pose anything anyway. It was just a little strange all the other aircraft were super tight, and these were flopping around. I don’t have a set, but I’d guess the Ork Eavy Bommers are the same way. I could have done more with the paint jobs, but I figured it was adequate tabletop standard. Averland Sunset for the win! walter h and Firedrake Cordova 2 Back to top Link to comment https://bolterandchainsword.com/topic/363802-grot-bommers-completedissue/#findComment-5520117 Share on other sites More sharing options...
Mandragola Posted May 13, 2020 Share Posted May 13, 2020 I’ve found the Grot bommers are loose too. I thought about maybe adding some GS in there. That would probably just get stuck anyway though. Link to comment https://bolterandchainsword.com/topic/363802-grot-bommers-completedissue/#findComment-5520904 Share on other sites More sharing options...
Firedrake Cordova Posted May 13, 2020 Share Posted May 13, 2020 (edited) I don’t have a set, but I’d guess the Ork Eavy Bommers are the same way. I just checked my (unassembled) set, and the interference fit, whilst not "sloppy", is less tight than the other kits. I imagine I'll be filling the socket a little with some acrylic putty to tighten the fit a bit. Edited May 13, 2020 by Firedrake Cordova Link to comment https://bolterandchainsword.com/topic/363802-grot-bommers-completedissue/#findComment-5520908 Share on other sites More sharing options...
Fajita Fan Posted May 13, 2020 Share Posted May 13, 2020 Blue tack is a good, non-permanent to stick things on for a game. I'm using it for square bases on my round bases for my WHFB models in AoS. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/363802-grot-bommers-completedissue/#findComment-5520938 Share on other sites More sharing options...
plastic_slug Posted May 14, 2020 Author Share Posted May 14, 2020 Good to know if I get some Ork Bommers for my game. The slightest knock would send my Grot Bommer off the stand. Blue Tack might be a good solution as well. Thanks. Firedrake Cordova 1 Back to top Link to comment https://bolterandchainsword.com/topic/363802-grot-bommers-completedissue/#findComment-5521117 Share on other sites More sharing options...
