Skywrath Posted May 13, 2020 Share Posted May 13, 2020 What kind of terrain do you use for your GK army? Personally, I have a pot of Valhallan Blizzard sitting next to me, but the contrast of white snow to grey armor wouldn't look as striking as green armor to snow. So what type of terrain would you recommend, and how would you go about it creating it? Link to comment https://bolterandchainsword.com/topic/363857-terrain-bases/ Share on other sites More sharing options...
The Neverborn Posted May 13, 2020 Share Posted May 13, 2020 As a rule of thumb, There are two ways to go. From what i've scene Light basis look better on dark models and dark basis look better on light models Or They are painted roughly the same pitch/shade but add to the theme - ie. space wolves in snow Also pro snow tip - to get the best snow use the following, bicarbonate of soda (2/3), White paint(1) and PVA glue (1). My Eldar army is done in that way and it looks much better than the Valhallan Bliizard stuff. It's in the loft but I might try and dig it out if you're really keen. BBA Link to comment https://bolterandchainsword.com/topic/363857-terrain-bases/#findComment-5521102 Share on other sites More sharing options...
W.A.Rorie Posted May 13, 2020 Share Posted May 13, 2020 (edited) Urban Edit added Pics Edited May 14, 2020 by war009 Brother Lunkhead 1 Back to top Link to comment https://bolterandchainsword.com/topic/363857-terrain-bases/#findComment-5521110 Share on other sites More sharing options...
Skywrath Posted May 14, 2020 Author Share Posted May 14, 2020 Thanks for the responses. With regards to the bi-carb, would't it have issues sticking on, if by any chance you get rain on top of it? Wouldn't mind seeing how it looks like though. As for the urban bases, at first, a picture came into my mind of the necromunda bases (which I'm not a fan of). How did you get that skeleton on the base though? Link to comment https://bolterandchainsword.com/topic/363857-terrain-bases/#findComment-5521331 Share on other sites More sharing options...
W.A.Rorie Posted May 14, 2020 Share Posted May 14, 2020 The skeletons I had for a while. They are from wargames factory. Smaller than GW skeletons. I don’t think they would be good for an army of skeletons but for bits on base they are great. Link to comment https://bolterandchainsword.com/topic/363857-terrain-bases/#findComment-5521343 Share on other sites More sharing options...
The Neverborn Posted May 14, 2020 Share Posted May 14, 2020 (edited) Thanks for the responses. With regards to the bi-carb, would't it have issues sticking on, if by any chance you get rain on top of it? Wouldn't mind seeing how it looks like though. As for the urban bases, at first, a picture came into my mind of the necromunda bases (which I'm not a fan of). How did you get that skeleton on the base though? That's what you mix the PVA glue in for, it dries solid as you like I'll see if I can did out a good photo For my Wraightknight I happened across a dreadnought to add a little extra to the base, it wasn't painted so i gave it a quick spray in high-contrast colour to my theme For a lot of the models I actually used Vanahlla or perhaps a pre-cusor and used the bi-carb. It give a soft snow effect Table top The models here are around 5+ years old so they mixture has aged as much as it ever will. The white paint is key as without they the mixture goes green after a few weeks. Edited May 14, 2020 by Battle Brother Abderus Valerian and Skywrath 2 Back to top Link to comment https://bolterandchainsword.com/topic/363857-terrain-bases/#findComment-5521460 Share on other sites More sharing options...
Valerian Posted May 14, 2020 Share Posted May 14, 2020 What kind of terrain do you use for your GK army? Are you just talking about the basing of the models? Not the terrain on the actual gaming table? Link to comment https://bolterandchainsword.com/topic/363857-terrain-bases/#findComment-5521526 Share on other sites More sharing options...
Skywrath Posted May 14, 2020 Author Share Posted May 14, 2020 Terrain on the base :p So can be applied to both in reality, however more to the former than the latter. Link to comment https://bolterandchainsword.com/topic/363857-terrain-bases/#findComment-5521532 Share on other sites More sharing options...
Valerian Posted May 14, 2020 Share Posted May 14, 2020 In that case, I went with the hell-world theme: Brother Lunkhead and W.A.Rorie 2 Back to top Link to comment https://bolterandchainsword.com/topic/363857-terrain-bases/#findComment-5521589 Share on other sites More sharing options...
Skywrath Posted May 15, 2020 Author Share Posted May 15, 2020 How did you do the hellworld theme? Looks pretty good. @Aberus, very good as well. I'll try that recommendation out. Link to comment https://bolterandchainsword.com/topic/363857-terrain-bases/#findComment-5521650 Share on other sites More sharing options...
Freakshow668 Posted May 15, 2020 Share Posted May 15, 2020 Mine are all on grassy/earthy/wildernessy bases. Easy to knock out en masse and I think it gives them a "knights in shining armour" vibe. W.A.Rorie, Valerian and Brother Lunkhead 3 Back to top Link to comment https://bolterandchainsword.com/topic/363857-terrain-bases/#findComment-5521751 Share on other sites More sharing options...
W.A.Rorie Posted May 15, 2020 Share Posted May 15, 2020 Love the models, very nicely done, freak show Freakshow668 1 Back to top Link to comment https://bolterandchainsword.com/topic/363857-terrain-bases/#findComment-5521778 Share on other sites More sharing options...
Skywrath Posted May 15, 2020 Author Share Posted May 15, 2020 Loving the work my dude. Personally I prefer bases that have a bit more character, such as icy ones, as I see dirt or sandy ones as too simple. But that's just me. Link to comment https://bolterandchainsword.com/topic/363857-terrain-bases/#findComment-5521809 Share on other sites More sharing options...
