See title. Has someone used them and can share experience with them?
Be it rust or dust? I have a bunch of pigments, but I shy away from using them a lot of the time because
a) for rust I find crusted rust deposits from ak to be way more dramatic and easy to use
b) Fixing is such a hassle
I am kind of hoping these might be cool, because greenstuffworlds Pigment Fixer is actually pretty good.
https://bolterandchainsword.com/topic/363930-greenstuffworld-liquid-pigments/
When fixing with a brush you are supposed to tap it to the pigment and let the capillary action do its thing right?
I always loose a bunch of pigment doing that. Maybe I should spray the fixer. I have vallejos and greenstuffworlds fixer.
Funnily enough I was applying weathering powder yesterday and wondering how to apply the pigment fixer. I might have to try spraying it next time I'm able to find room to use my airbrush.
Don't spray it, and try AK Interactive's instead. It works great by capillary action. I used Vallejo's for years and wondered why my finish was always crap. Or simply use an enamel wash, works 90% as well and gives you more options. It was in my Weathering ZM Bases tutorial...:whistling:
Edited by Lovecraft0110
  • 2 weeks later...
I got the 3 of the rust ones in asset drop, used them on some necromunda bases and they work pretty well.
No fixing needed and you can build up layers pretty easily and drybrush over them with no issue.
Register a new account
Sign in
