Successor Chapters mixing Chapter Tactics
If I have two detachments from the same Successor Chapter but with different Chapter Tactics, Long Range Marksmen and Master Artisans in one and Long Range Marksmen and Scions of the Forge in the other, do I lose access to Super Doctrines or anything else?
Thanks,
A chapter can at most have two chapter tactics:
Unless otherwise stated, your Chapter has two Successor Tactics from the following list:
So either you must drop one chapter tactic, or you have two chapters with the same name. So either you must drop one or you lose the Super Doctrines.
