Raven1 Posted May 28, 2020 Share Posted May 28, 2020 I finally picked up a copy of Ritual of the Damned and was reading through the book and I had a question about the interaction between devastating sorcery and Firestorm of Tzeentch. So Devastating Sorcery add +1 mortal wound to any psychic power which causes at least one mortal wound sound simple enough. Firestorm of Tzeentch causes a mortal wound on a roll of "6" where you get to roll 9 dice. So where does the +1 mortal wound come into play. 1. On a successful cast as the psychic power causes mortal wounds? 2. On at least one "6" you get +1 mortal wound? 3. On every "6" you get +1 mortal wound? I would wager its the second one, but I what do I know? Link to comment https://bolterandchainsword.com/topic/364183-firestorm-of-tzeentch-and-devastating-sorcery-question/ Share on other sites More sharing options...
WarriorFish Posted May 28, 2020 Share Posted May 28, 2020 It's the second, as the rule stipulates "at least one mortal wound" so it only triggers once for each power :tu: Link to comment https://bolterandchainsword.com/topic/364183-firestorm-of-tzeentch-and-devastating-sorcery-question/#findComment-5530952 Share on other sites More sharing options...
Prot Posted May 28, 2020 Share Posted May 28, 2020 It's the second, as the rule stipulates "at least one mortal wound" so it only triggers once for each power Well not quite. It's triggered on each unit, not each power. So Astral Blast: It goes off, ripping into a target unit (add 1 mortal wound). Then it hits a few units within an aura (add 1 Mortal wound to each other unit hit.) Think of it per unit. So with your example of Firestorm, you're only hitting one unit. Just add 1 MW. Link to comment https://bolterandchainsword.com/topic/364183-firestorm-of-tzeentch-and-devastating-sorcery-question/#findComment-5531131 Share on other sites More sharing options...
WarriorFish Posted May 28, 2020 Share Posted May 28, 2020 That's what I meant yes, the "at least one" is the part here :tu: When in doubt assume the weaker interpretation and you're probably not wrong (and people will be more happy to accept it!). Link to comment https://bolterandchainsword.com/topic/364183-firestorm-of-tzeentch-and-devastating-sorcery-question/#findComment-5531203 Share on other sites More sharing options...
