Glute Posted June 8, 2020 Share Posted June 8, 2020 So if you apply Gate of Infinity to a unit can that unit also have Dynamic Insertion applied to them? Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/ Share on other sites More sharing options...
Corvus Fortis Posted June 8, 2020 Share Posted June 8, 2020 So if you apply Gate of Infinity to a unit can that unit also have Dynamic Insertion applied to them? No, dynamic insertion can only be activated when the unit is set up using Teleport Strike ability. This, by the way means, that you cannot use it on Draigo, for example, thanks to fluffy desctiption. W.A.Rorie and Valerian 2 Back to top Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5537644 Share on other sites More sharing options...
casb1965 Posted June 9, 2020 Share Posted June 9, 2020 On the matter of dynamic insertion can someone explain the benefits of using it over a normal deep strike. Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538012 Share on other sites More sharing options...
Captain Coolpants Posted June 9, 2020 Share Posted June 9, 2020 (edited) On the matter of dynamic insertion can someone explain the benefits of using it over a normal deep strike. contesting an objective mainly. Or getting right in front of a troublesome unit or character that the enemy thought was screened by keeping units 9" away from each other Or a cheeky cheap single character to squeeze right in front of another character and cast inner fire Edited June 9, 2020 by Captain Coolpants Corvus Fortis 1 Back to top Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538076 Share on other sites More sharing options...
Skywrath Posted June 9, 2020 Share Posted June 9, 2020 (edited) On the matter of dynamic insertion can someone explain the benefits of using it over a normal deep strike.contesting an objective mainly. Or getting right in front of a troublesome unit or character that the enemy thought was screened by keeping units 9" away from each other Or a cheeky cheap single character to squeeze right in front of another character and cast inner fire You wouldn't be thinking of an apothecary would you, sir? ;p Edited June 9, 2020 by Skywrath Captain Coolpants 1 Back to top Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538084 Share on other sites More sharing options...
Corvus Fortis Posted June 9, 2020 Share Posted June 9, 2020 Another application is covering your heroes with placing a squad closer to enemies. Captain Coolpants 1 Back to top Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538092 Share on other sites More sharing options...
Seizeman Posted June 9, 2020 Share Posted June 9, 2020 I guess the original intention was to be able to deploy incinerators in range. With some luck, they'll become playable in 9th. Captain Coolpants and Valerian 2 Back to top Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538096 Share on other sites More sharing options...
casb1965 Posted June 9, 2020 Share Posted June 9, 2020 On the matter of dynamic insertion can someone explain the benefits of using it over a normal deep strike.contesting an objective mainly. Or getting right in front of a troublesome unit or character that the enemy thought was screened by keeping units 9" away from each other Or a cheeky cheap single character to squeeze right in front of another character and cast inner fire See, I thought those things to start with but Dynamic Insertion 1. drops you > 3" so unless your opponents troops are not ON the objective you will struggle to contest it. 2. Inner fire has a 1" range so you can't cast it. Even a Purifier squad is outside of Purifying Flame range unless you spend a 2nd CP to drop a Brother Captain with them. The only thing I thought off was dropping between screens and characters and then your 5 man squad will be able to get off 40 storm bolter shots or creating a screen to protect your characters. Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538113 Share on other sites More sharing options...
Trollbeard Posted June 9, 2020 Share Posted June 9, 2020 I recently used it to drop a 10 man paladin squad with 4 incinerators to be in range to actually fire them. Was very effective, melted a warboss on a wartrike. And you can use Inner Fire if you use the “Powerful adept” stratagem as well. Captain Coolpants 1 Back to top Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538153 Share on other sites More sharing options...
Corvus Fortis Posted June 9, 2020 Share Posted June 9, 2020 1. drops you > 3" so unless your opponents troops are not ON the objective you will struggle to contest it. 2. Inner fire has a 1" range so you can't cast it. 1. Sometimes your opponent not in range of the objective, but stil denies you grabbing in from DS. For example, they sent a guardsment squad to take an objective, and they are like 5" from the center. You can drop a squad in 3" and grab it. 2. With powerful adept the range is increased to 7". Used it several times, worked quite well. Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538434 Share on other sites More sharing options...
casb1965 Posted June 9, 2020 Share Posted June 9, 2020 So Castellan Crowe with Dynamic Insertion and Powerful Adept could do d6 smite ,throw on Empyric Surge for another +1 to cast.and Inner Fire becomes cast on 2d6+2. Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538532 Share on other sites More sharing options...
librisrouge Posted June 10, 2020 Share Posted June 10, 2020 So Castellan Crowe with Dynamic Insertion and Powerful Adept could do d6 smite ,throw on Empyric Surge for another +1 to cast.and Inner Fire becomes cast on 2d6+2. Nope, he can't Dynamic Insertion because he cannot teleport. Corvus Fortis 1 Back to top Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538705 Share on other sites More sharing options...
casb1965 Posted June 10, 2020 Share Posted June 10, 2020 So Castellan Crowe with Dynamic Insertion and Powerful Adept could do d6 smite ,throw on Empyric Surge for another +1 to cast.and Inner Fire becomes cast on 2d6+2. Nope, he can't Dynamic Insertion because he cannot teleport. Damn you're right, just like Purifiers can't. Two units that could make real good use of the strat. So seeing as Inner Fire is a Dominus discipline power only unnamed Characters can know it, does limit our choices (or have they FAQ'ed that) Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538836 Share on other sites More sharing options...
Corvus Fortis Posted June 10, 2020 Share Posted June 10, 2020 So seeing as Inner Fire is a Dominus discipline power only unnamed Characters can know it, does limit our choices (or have they FAQ'ed that) How? Any character can have dominus powers. There's no limitations. Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538853 Share on other sites More sharing options...
casb1965 Posted June 10, 2020 Share Posted June 10, 2020 So seeing as Inner Fire is a Dominus discipline power only unnamed Characters can know it, does limit our choices (or have they FAQ'ed that) How? Any character can have dominus powers. There's no limitations. Because I'm a numbnut and misread the set warlord traits for Draigo, Voldus etal as psychic powers. I need more coffee Corvus Fortis 1 Back to top Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538855 Share on other sites More sharing options...
Skywrath Posted June 10, 2020 Share Posted June 10, 2020 So seeing as Inner Fire is a Dominus discipline power only unnamed Characters can know it, does limit our choices (or have they FAQ'ed that) How? Any character can have dominus powers. There's no limitations. Because I'm a numbnut and misread the set warlord traits for Draigo, Voldus etal as psychic powers. I need more coffee Everyone makes mistakes, brother. I make a lot of those, but what's the most important thing is, you are learning :) Link to comment https://bolterandchainsword.com/topic/364419-gate-of-infinity-with-dynamic-insertion-valid-yes-or-no/#findComment-5538859 Share on other sites More sharing options...
