1s=heretical Posted June 13, 2020 Share Posted June 13, 2020 With the unboxing noticed they didnt just include green wing transfers but for both death and ravenwing. Safe to say bikes are ravenwing. Thoughts on what would be the newly inducted deathwing primaris Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/ Share on other sites More sharing options...
Gederas Posted June 13, 2020 Share Posted June 13, 2020 (edited) With the unboxing noticed they didnt just include green wing transfers but for both death and ravenwing. Safe to say bikes are ravenwing. Thoughts on what would be the newly inducted deathwing primaris Well, when the Outrider Bikers were officially revealed, they did specify Ravenwing, not simply "Dark Angels" when referring to them being available to us. And for those wondering, here's the picture. We're on the bottom because we take up so much space :lol: Edited June 13, 2020 by Gederas Spyros 1 Back to top Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5540719 Share on other sites More sharing options...
Skywrath Posted June 13, 2020 Share Posted June 13, 2020 The bigger question is, seeing how this box is probably larger than Dark Imperium, what's it's price going to be? Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5540750 Share on other sites More sharing options...
1s=heretical Posted June 13, 2020 Author Share Posted June 13, 2020 Theres 5 so I think now that looking at it it's for the sword and shield guys along with cap and lt Quixus 1 Back to top Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5540752 Share on other sites More sharing options...
WrathOfTheLion Posted June 13, 2020 Share Posted June 13, 2020 (edited) I think the transfers are just general. There are also vehicle transfers, which obviously don't apply to the box. There are more chapter icons than needed as well, so I think it's meant to be useful for more than just the box. The current transfer sheet also has deathwing icons.What is more interesting, is the veteran transfers, which I think are for the bladeguard. Those are not on the current transfer sheet. Edited June 13, 2020 by WrathOfTheLion Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5540832 Share on other sites More sharing options...
Gederas Posted June 13, 2020 Share Posted June 13, 2020 What is more interesting, is the veteran transfers, which I think are for the bladeguard. Those are not on the current transfer sheet. They are. I've gotten Deathwing Terminators and the Ravenwing Black Knights they come with a transfer sheet that has the red Veteran sword. Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5540867 Share on other sites More sharing options...
WrathOfTheLion Posted June 13, 2020 Share Posted June 13, 2020 (edited) What is more interesting, is the veteran transfers, which I think are for the bladeguard. Those are not on the current transfer sheet. They are. I've gotten Deathwing Terminators and the Ravenwing Black Knights they come with a transfer sheet that has the red Veteran sword. Those are for lieutenants, although they are mentioned for veterans in the codex I think. I am talking about the new veteran cross with what looks like a skull in the center to the right of the close combat marking, and above the lieutenant/old veteran swords. I think they are adding that as our veteran insignia to have separate lieutenant/veteran markings. Edited June 13, 2020 by WrathOfTheLion Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5540878 Share on other sites More sharing options...
Skywrath Posted June 13, 2020 Share Posted June 13, 2020 Regardless of their intent behind adding the tri-wing to the decal sheet, mine veterans are going to be "inducted" into the Deathwing with those red decals and bone-white scheme. That seems too good to pass up. Although, this release does make me wonder, if this was planned for Adepticon (or whatever the name was), is this truly it, or were there more coming? This release was huge, but I suspect there is even more, especially if this is on the same tier of magnitude when primaris were announced. Not to mention the way I see it, if these units are replacing the firstborn versions, then we have nearly completed the "transfer" process. Then the next chamber should be either the proposed vehicle one, or the custom chapter chamber. So which means chapter-specific units such as Primaris Deathwing. Zebukkuk 1 Back to top Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5540891 Share on other sites More sharing options...
Interrogator Stobz Posted June 13, 2020 Share Posted June 13, 2020 Huge leaps here; GW transfer sheets have included this kind of variety for 30 years, it's not new or different. Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5541062 Share on other sites More sharing options...
Master Sheol Posted June 13, 2020 Share Posted June 13, 2020 There is 24 standard DA chapter badges and the miniatures in the box are Just 18 plus 3 bikes So the DW markings don't mean anything While the RW markings are 9 and this is the right amount for 3 bikes So the Bladeguard Veterans can still be Just Company Veterans as i guess they are The only miniature Is the veterani ancient that Is supposed to be a sort of 1st Company ancient but in the DA this could take the role of Brother Bethor and carry a sort of "sacred standard" in this case he could be a DW member like Bethor was but Bethor were in green PA with regular DA chapter badge Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5541075 Share on other sites More sharing options...
shabbadoo Posted June 14, 2020 Share Posted June 14, 2020 GW states the savings will be more than 50%, but look at what is included just for Primaris: *5 Characters $150-ish* 10 Primaris $60 3 Outrider Bikes $60 3 Sword Vets. $35-ish 3 Melta Rifles $35-ish -------------------------------------- Roughly $340-ish US. Loaded with "prermium" units that are pricey. A bit less than 50% of that would be $150, but I don't think the starter set will be $300. I think store cost on this will be about $140US, with a retail price of about $240. The Necrons have a similar load-out character-/large model-wise, but I think a $300 US price tag will not be a great price point (especially right now), no matter how much they say, "This is the greatest starter set we have made, EVAR!!!" That they are pimping the savings so blatantly makes me cringe a lil' bit, in that we may be in for a price shock. Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5541310 Share on other sites More sharing options...
Gederas Posted June 17, 2020 Share Posted June 17, 2020 Well, turns out we found out what the Deathwing transfers are for.... This just raises further questions! :lol: Magos Valkamar, Helias_Tancred, Zebukkuk and 3 others 6 Back to top Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5543536 Share on other sites More sharing options...
Marshal Loss Posted June 17, 2020 Share Posted June 17, 2020 Gods that looks good Zebukkuk 1 Back to top Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5543546 Share on other sites More sharing options...
Skywrath Posted June 17, 2020 Share Posted June 17, 2020 Brothers, may I request the source of that picture? Regardless of how they look like on that picture, my primaris are going to be in 3rd edition deathwing colors ;p Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5543547 Share on other sites More sharing options...
Master Sheol Posted June 17, 2020 Share Posted June 17, 2020 (edited) If they have 2+ and they can teleport they are DW If not they are freebooters :D @Skywrath It's official from GW 40k FB page Edited June 17, 2020 by Master Sheol Helias_Tancred and Skywrath 2 Back to top Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5543554 Share on other sites More sharing options...
1s=heretical Posted June 17, 2020 Author Share Posted June 17, 2020 Brothers, may I request the source of that picture? Regardless of how they look like on that picture, my primaris are going to be in 3rd edition deathwing colors ;p It's off the Facebook warhammer page Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5543563 Share on other sites More sharing options...
Skywrath Posted June 17, 2020 Share Posted June 17, 2020 Thanks, brothers. Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5543567 Share on other sites More sharing options...
1s=heretical Posted June 17, 2020 Author Share Posted June 17, 2020 It's off the Facebook warhammer page Much to learn on this forum didnt mean to double post. But seems like this box is going to tri wing for sure Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5543568 Share on other sites More sharing options...
Robbienw Posted June 17, 2020 Share Posted June 17, 2020 Actual heresy :yuck: Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5543629 Share on other sites More sharing options...
WrathOfTheLion Posted June 17, 2020 Share Posted June 17, 2020 Interesting, I stand corrected on what I thought they would do.The bladeguard veterans do remind me of the 30k deathwing companions. Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5543675 Share on other sites More sharing options...
JimVandy85 Posted June 17, 2020 Share Posted June 17, 2020 Who here is considering lobbing off those shields for the dwk shields? Magos Valkamar, Helias_Tancred, Zebukkuk and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5543950 Share on other sites More sharing options...
JJD Posted June 18, 2020 Share Posted June 18, 2020 It looks like power armour is coming to the Deathwing. I really hope we get some clarification as to what the Ravenwing and Deathwing will look like in a primaris future. I’m worried they will lose their unique identity. Interrogator Stobz 1 Back to top Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5544345 Share on other sites More sharing options...
Knight Artorias Posted June 18, 2020 Share Posted June 18, 2020 (edited) They just confirmed that the Bladeguard Veterans are Deathwing. Which suggests that the Bladeguard characters are meant to be too. Of course you can paint them however you like, I think I'm still going to do them as just company veterans. https://www.warhammer-community.com/2020/06/18/indomitus-focus-alternate-colour-schemesgw-homepage-post-3/ Edited June 18, 2020 by Knight Artorias G8Keeper 1 Back to top Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5544391 Share on other sites More sharing options...
Gederas Posted June 18, 2020 Share Posted June 18, 2020 (edited) They just confirmed that the Bladeguard Veterans are Deathwing. Which suggests that the Bladeguard characters are meant to be too. Of course you can paint them however you like, I think I'm still going to do them as just company veterans. [image snipped] https://www.warhammer-community.com/2020/06/18/indomitus-focus-alternate-colour-schemesgw-homepage-post-3/ So, no lie. They look really good in Deathwing colours. The real question is if GW will remember to give them the DEATHWING keyword though when in a Dark Angels army :lol: Edited June 18, 2020 by Gederas G8Keeper and Zebukkuk 2 Back to top Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5544393 Share on other sites More sharing options...
G8Keeper Posted June 18, 2020 Share Posted June 18, 2020 Let's hope they can teleport too! Link to comment https://bolterandchainsword.com/topic/364502-9th-launch-comes-with-tri-wing-transfers/#findComment-5544397 Share on other sites More sharing options...
