GrFlur Posted June 21, 2020 Share Posted June 21, 2020 Hi there I'm trying to design a battle table and I'm just curious about distances. How much the roads (space betwwen buildings) measure? How many cm or Inch there is? Link to comment https://bolterandchainsword.com/topic/364649-terrain-measurements/ Share on other sites More sharing options...
Grotsmasha Posted June 21, 2020 Share Posted June 21, 2020 There is no "set" distance, it is entirely up to your discretion. A good practice is to consider the models you'll be using, and whether of not they will fit. You may have smaller infantry only gaps, and then a main boulevard large enough for an Imperial Knight. GrFlur and Gederas 2 Back to top Link to comment https://bolterandchainsword.com/topic/364649-terrain-measurements/#findComment-5546197 Share on other sites More sharing options...
Gederas Posted June 21, 2020 Share Posted June 21, 2020 There is no "set" distance, it is entirely up to your discretion. A good practice is to consider the models you'll be using, and whether of not they will fit. You may have smaller infantry only gaps, and then a main boulevard large enough for an Imperial Knight. That's usually how I treat table terrain set-ups. Make it so there's gaps in certain areas that anything can fit through, and other gaps that only infantry/small vehicles can fit through. For example, when I helped my (sadly now-closed and previous) FLGS with tournament prep, we used my Brass Scorpion (I was playing World Eaters) as a benchmark. If my Scorpion could fit through some areas of the board, anything people could bring to a 1750 Tournament could. GrFlur and The Ergonomic Enginseer 2 Back to top Link to comment https://bolterandchainsword.com/topic/364649-terrain-measurements/#findComment-5546206 Share on other sites More sharing options...
