How to begin to build a Space Marine Company with miniatures
Greetings one and all,
I am struggling to find information that helps me understand the composition of Space Marine companies and how i can use my miniatures to build a company.
The following is a list of the Primaris Units i have:
3x Intercessor Squads
2x Reiver Squads
2x Hellblaster Squads
2x Infiltrator Sqaud
5x Aggressor Sqauds
5x Inceptor Squads
3x Redemptor Dreadnaughts
Captains
2x Ancients
Lieutenants
Librarians
Apothecary
Chaplain
2x Respulsor
Respulsor Executioner
If anyone could advise how these can be organised into a company so i can begin to paint them and give them company and squad markings it would be very much appreciated.
Also i have the following first gen Space Marine Miniatures:
3x 5 men Terminator squads
5x tactical squads
Sternguard Veterans
2x Vanguard Veterans
2x devastator Squads
3x Assault Squads
3x Bike Squads
4x Rhinos/Razerbacks
4x Land Speeders
2x scouts
scouts with sniper rifles
Gunship
2x Command Squads
Captain
librarian
Chaplain
3x Dreadnaughts
Attack Bike
Drop Pod
If anyone could also advise how these can be organised into a company so i can begin to paint them and give them company and squad markings it would be very much appreciated.
Google/chosen search engine "Space Marine Company" and you should be able to get several sources to help understand the general structure of a Space Marine Company. Looking at some older Edition Marine Codexes will help too - I'm sure those are available online somewhere.
The elements you have listed are typically broken up across multiple companies (at least of the Classic Astartes), not members of the same company.
You can find a chart depicting the basic composition of a Codex Chapter on page 17 of the 8th edition version of Codex: Space Marines.
In general, each company includes:
  • 1x Captain
  • 2x Lieutenants
  • 1x Chaplain (these aren't listed above, but have been organic to a company since 2nd edition)
  • 1x Ancient (these aren't listed above, but have been organic to a company since 2nd edition)
  • 1x Apothecary (these aren't listed above, but have been organic to a company since 2nd edition)
  • 1x Command Squad (the 1st Company has an Honour Guard instead, and the 10th Company doesn’t have a Command Squad)
  • Some number of dreadnoughts (except the 10th Company)
Techmarines and Librarians are not part of companies, but may be attached to companies/detachments as necessary. Techmarines normally belong to the Forge (under the Master of the Forge), but it's common for 1 or more to be attached to a detachment. Librarians belong to the Librarius under the Chief Librarian(s), but there will be at least one per ship (since one of their roles is to provide communications).
Additional Apothecaries can be sourced from the Apothecarion and additional Chaplains might be sourced from the Reclusiam.
The only vehicles that are organic to most companies are the standard transports (Rhinos and drop pods). Additional vehicles may be attached to companies/detachments as necessary.
Battleline Squads: Tactical, Intercessor, Vanguard Infiltrator
Close Support Squads: Assault, Inceptor, Reiver, Incursor
Fire Support Squads: Devastator, Hellblaster, Aggressor, Vanguard Eliminator, Vanguard Suppressor
Veterans: Sternguard, Vanguard, Terminator [Assault], and soon Bladeguard (and maybe others)
Prior to the Ultima Founding and the introduction of the Primaris Space Marines, Chapter organization would have been largely similar to what you see in the chart above, minus the Lieutenants and Primaris. For example, a Battle Company would consist of 6 Tactical Squads, 2 Assault Squads, and 2 Devastator Squads (in addition to the stuff described above the chart). From that, a pure Battle Company might employ its Assault Squads as bikers or Land Speeders.
Commonly, however, the Adeptus Astartes don’t operate as pure companies. Instead, they’ll form detachments. The core of a detachment will be some portion of a Battle Company and it will be augmented from vehicles from the armoury and squads from other companies (usually the 1st, 6th, 7th, 8th, 9th, and 10th Companies).
As far as I can tell, SM in Dark Millenium era roll as demi companies with extra's in support. That gives them twice the force projection with specialist assets supporting the traditional company structure. In the old 8th ed SM dex, p26-27, shows UM 2nd co, mix of primaris and old marines. The primaris are at minimum squad sizes, so a pure primaris demi co would be tiny and still valid as a company structure. Also post RG's comeback, seems everyone integrates primaris different, some mix, some separate and others just dump the primaris into existing full strength units (BT, SW etc). You are pretty close to hitting a company anyway with what you got right now technicaly with the new lore.
I'm assuming these squads are by box size (ie tactical = 10, bike = 3, assault = 5 etc).
PRIMARIS
Command
Captains
2x Ancients
Lieutenants
Librarians
Apothecary
Chaplain
Battleline
2x Infiltrator Squad
Close Support
2x Reiver Squads
5x Inceptor Squads
Fire Support
5x Aggressor Squads
Armoury
2x Repulsor
Repulsor Executioner
In terms of units for a Primaris company, the only thing you're short of is battleline units, though you've got more fire support and close support than you need. If you've not finished putting everything together yet, you could use spare arms from some intercessors and a box of hellblasters to make an extra squad of intercessors. That would then give you 60 battleline, 35 close support, and 25 fire support. You could then pick out 15 close support and 5 five support to be seconded from a different company. You could then give your 100 from the main company all the same company markings, and sequentially number them through by squad (ie BL 1-6, CS 7-8, FS 9-10) and then either paint the seconded units with reserve company markings and give them whatever numbers you want (if the secondment was short term) or main company markings and give them numbers >10 if the secondment was long term.
FIRSTBORN
Command
2x Command Squads
Captain
Librarian
Chaplain
Battleline
5x tactical squads
Close Support
3x Assault Squads
3x Bike Squads
Attack Bike
Fire Support
Armoury
4x Rhinos/Razorbacks
4x Land Speeders
Gunship
3x Dreadnaughts
Drop Pod
10th Co Detachment
2x scouts
Scouts with sniper rifles
1st Co Detachment
Sternguard Veterans
The veterans and scouts will have to be from their own companies - 10th co tend not to use company markings, 1st tend to use white. You've got few enough of each that you can number the squads however you want. Your battleline here is fine - number those tactical squads 1-5 - you just need one more squad, battleline 6. Close support is a bit trickier - you could lump all the bikes (and attack bike) together and call them squad 7. There's then the question of what to do with the 15 assault marines - 10 of them could be called squad 8, and the other 5 could either be seconded in from another company, or you could paint them up as vanguard veterans. Fire support, if those are just the five man squads without filler marines with bolters, is too small - you'd need another ten marines with bolters, five in each squad, or you could do two more half sized devastator squads so you have all the weapon options.
