SvenIronhand Posted July 3, 2020 Share Posted July 3, 2020 I was thinking that, since my Bladeguard proxies wear Phobos and thus smaller than the "real" models, I'd cover the base with something else. I was thinking of doing a traitor casualty by taking the front torso bit, a head, and burying that in PVA glue to hide the missing bits. But I wanted a second opinion. Link to comment https://bolterandchainsword.com/topic/364866-csm-casualties-for-my-bases-how-would-you-model-this/ Share on other sites More sharing options...
pawl Posted July 3, 2020 Share Posted July 3, 2020 I've always been confused by casualties that seem to simply melt into the ground - if you're fighting in say an urban setting does the stone/concrete/whatever simply swallow up anything that falls over? Personally I prefer the idea of fully modelled casualties in most situations. Link to comment https://bolterandchainsword.com/topic/364866-csm-casualties-for-my-bases-how-would-you-model-this/#findComment-5554060 Share on other sites More sharing options...
MegaVolt87 Posted July 8, 2020 Share Posted July 8, 2020 The trick with urban bases is to have bits of busted rock/concrete, churned up dirt is how things would sink, or gravel for more built up urban areas. Or chunk up the rocks to show a collapse, moved rubble showing what was buried. Link to comment https://bolterandchainsword.com/topic/364866-csm-casualties-for-my-bases-how-would-you-model-this/#findComment-5557386 Share on other sites More sharing options...
Xenith Posted July 8, 2020 Share Posted July 8, 2020 I've always been confused by casualties that seem to simply melt into the ground - if you're fighting in say an urban setting does the stone/concrete/whatever simply swallow up anything that falls over? Personally I prefer the idea of fully modelled casualties in most situations. Casualties fall over, but then so do buildings, and dirt flies everywhere with explosive munitions. The very recently deceased would be on top, but those are better for objective markers. Link to comment https://bolterandchainsword.com/topic/364866-csm-casualties-for-my-bases-how-would-you-model-this/#findComment-5557468 Share on other sites More sharing options...
