Hugoboss8901 Posted July 5, 2020 Share Posted July 5, 2020 So I'm doing an Ashen claws force. And I just wanted to know can I use rg legion rules for ashen claws? Also the Ashen claws did they wear the red pads etc before they got exiled or did that happen after? Link to comment https://bolterandchainsword.com/topic/364899-can-i-use-rg-legion-rules-for-ashen-claws/ Share on other sites More sharing options...
Dagoth Ur Posted July 5, 2020 Share Posted July 5, 2020 I don't think that anything says that you can't - hell, I even think it's a pretty neat idea! From a fluff perspective it makes sense too as Corax was around for a bit and started reshaping the legion before the terrans were exiled. The iconography only came afterwards I believe, but we have no strong indicator either way when it comes to that. When in doubt, do what you want :) Link to comment https://bolterandchainsword.com/topic/364899-can-i-use-rg-legion-rules-for-ashen-claws/#findComment-5555436 Share on other sites More sharing options...
SkimaskMohawk Posted July 5, 2020 Share Posted July 5, 2020 The ashen claws pretty much followed the same style of warfare as the wider legion, the main difference was their very callous views towards civilians and other forces. Like using army units as bait for an ambush or whatnot. It's also important to point out that corax was morally against their methods, but when he got pissed off his strategies would mirror theirs more and more. You can see him using the therion cohort as a distraction to insert his forces unharmed at the perfect fortress and then at yarrant. Or how he used torture and suicide troops in the primarch books. So there's really no difference between the legion and the exiles. Link to comment https://bolterandchainsword.com/topic/364899-can-i-use-rg-legion-rules-for-ashen-claws/#findComment-5555439 Share on other sites More sharing options...
The Scorpion Posted July 17, 2020 Share Posted July 17, 2020 So I'm doing an Ashen claws force. And I just wanted to know can I use rg legion rules for ashen claws? Also the Ashen claws did they wear the red pads etc before they got exiled or did that happen after? The heraldry change happened after. It is perfectly possible to play them as Raven Guard, but the Blackshield "Orphans of War" rules are probably a better fit considering the DT options for marauder squads and the "less sneaky" reaver tactics. Link to comment https://bolterandchainsword.com/topic/364899-can-i-use-rg-legion-rules-for-ashen-claws/#findComment-5565384 Share on other sites More sharing options...
Beren Posted July 17, 2020 Share Posted July 17, 2020 A slight issue might be that, if you were being pedantic about the fluff, the Ashen Claws would be considerably less likely to use any of the Raven Guard's special units. Link to comment https://bolterandchainsword.com/topic/364899-can-i-use-rg-legion-rules-for-ashen-claws/#findComment-5565504 Share on other sites More sharing options...
tychobi Posted July 17, 2020 Share Posted July 17, 2020 Yes. Dunno. Link to comment https://bolterandchainsword.com/topic/364899-can-i-use-rg-legion-rules-for-ashen-claws/#findComment-5565542 Share on other sites More sharing options...
