chapter master 454 Posted July 12, 2020 Share Posted July 12, 2020 Bit of a oddball for such a release really, considering the size of the box contents this strikes me as odd to release something that seems more geared for Combat Patrol along side such a massive set. Then again I suppose they also have those new weird board things now as well but I thought I would put it to my fellow fraters, a good idea or just a non-sense item with no purpose? (hey, it can double as a dice tray :P) Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/ Share on other sites More sharing options...
MegaVolt87 Posted July 12, 2020 Share Posted July 12, 2020 Well, if its only big enough for patrol/ kill team, you get the privilege of getting two for each indomi box you buy. Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5560657 Share on other sites More sharing options...
Tyberos the Red Wake Posted July 12, 2020 Share Posted July 12, 2020 It looks like it's the same as the old Kill Team one but with different colors/logo. Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5560707 Share on other sites More sharing options...
Impervious Posted July 12, 2020 Share Posted July 12, 2020 Heh, please. Keter ROC 22" toolbox, 40 EUR, made of metal reinforced high-impact resin, is water and temperature resistant, dustproof, comes with 25 years of warranty and swallows an entire shelf's worth of miniatures. It has a horizontal carrying position, so you can worry less about the stuff inside shifting. It's got built-in latches so you can securely stack them on top of each other, and you can put a padlock on it for maximum security. Only downside is, you have to buy and cut foam to build padding and holding trays for your figures. I'm in the process of finding a good source for it, and deciding exactly what kind of material would suit me best. The best material I've used in my carrying cases has been just a memory foam mattress topper. It's relatively easy to cut to the desired size and shape, it's pretty cheap, and it allows you to pack stuff in fairly tight, preventing the models from moving around. It also is simultaneously soft yet stiff enough to absorb small impacts without damaging the models. Just glue the layer of memory foam to a layer of conventional foam to make a "tray", and they can stack pretty easily. Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5560747 Share on other sites More sharing options...
Coolbeans Posted July 12, 2020 Share Posted July 12, 2020 I've never liked using foam. Takes paint/varnish/basing off. I prefer weak magnets under the bases and using an all metal tool box. They don't move and nothing touches them. Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5560950 Share on other sites More sharing options...
Schurge Posted July 12, 2020 Share Posted July 12, 2020 A waste of money. Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5560995 Share on other sites More sharing options...
HighMarshalAmp Posted July 13, 2020 Share Posted July 13, 2020 I've never liked using foam. Takes paint/varnish/basing off. Really? ............ I wish someone told me the figures crave self-destruction so much before I bought a bunch. Here we are, playing a game with gamepieces that are so fragile, at best they could be display models, no touching allowed EVER. It's the foam rubbing paint off the surface when you take models in and out that does it. Varnish helps, but it wears out as well if you constantly push your minis into snug foam compartments. Heck, there are gutar stands clad with foam that eat into the lacquer after a few months due to chemical reactions. It doesn't have to be about craving self destruction, it's just that sometimes, the obvious, easy solution of using cheap-as-chips foam isn't the best way to go long term. Edit: unless you weren't being sarcastic. In that case, use more glue Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5561828 Share on other sites More sharing options...
Coolbeans Posted July 13, 2020 Share Posted July 13, 2020 I've never liked using foam. Takes paint/varnish/basing off. Really? ............ I wish someone told me the figures crave self-destruction so much before I bought a bunch. Here we are, playing a game with gamepieces that are so fragile, at best they could be display models, no touching allowed EVER. It's the foam rubbing paint off the surface when you take models in and out that does it.Varnish helps, but it wears out as well if you constantly push your minis into snug foam compartments. Heck, there are gutar stands clad with foam that eat into the lacquer after a few months due to chemical reactions. It doesn't have to be about craving self destruction, it's just that sometimes, the obvious, easy solution of using cheap-as-chips foam isn't the best way to go long term. Edit: unless you weren't being sarcastic. In that case, use more glue Yeah I'm not sure if it was sarcastic or not haha. I mean use whatever works for you. I play chaos marine factions and have very involved bases, and the foam eats at the bases and all things spikey when putting them in and out. I got smart with my death guard in 8th and watched some guys YouTube video, he used some magnets and greenstuff/glue under the bases and put them in a metal toolbox. I got my plague marines, smaller characters and pox walkers in the top removable portion and some on the sides of the main, and have all my daemon engines in the main. I can hold the toolbox upside down and they don't move. Pretty convenient. Just don't get super big magnets. You'll pull your models off the bases before you pull the base off the metal haha. Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5561850 Share on other sites More sharing options...
Doctor Perils Posted July 20, 2020 Share Posted July 20, 2020 @coolbeans - with so many magnets, could there be problems if you're flying with your minis? Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5566828 Share on other sites More sharing options...
chapter master 454 Posted July 20, 2020 Author Share Posted July 20, 2020 Foam or not, its better than just carrying your models around in a plastic bag! (yes, played against someone that did that...my heart, soul and mind just...couldn't) Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5566856 Share on other sites More sharing options...
The Yncarne Posted July 20, 2020 Share Posted July 20, 2020 I’ve used foam and magnets. Foam seems to take a lot of space for my use case. I’m trying to move away from foam. I like being able to use a cookie sheet to move an army without fear of damage. I haven’t figured out the long term storage implications, but think a storage set with maximum shelves is the answer. Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5566877 Share on other sites More sharing options...
Gederas Posted July 20, 2020 Share Posted July 20, 2020 @coolbeans - with so many magnets, could there be problems if you're flying with your minis? I don't think so. I knew someone who routinely air-travelled with his army, and he used magnet cases. The most of an "issue" is he needed to pre-check his baggage for it, or if he couldn't inform the crew there that the case has a load of magnets in it, which might cause issues with scanning. Funny anecdote about that: Apparently one time one of the TSA people didn't believe him, put the magnet case through the scanner, and all the magnets caused the scanner to not even work. Like, the scan of his case just had a blank void in it :lol: Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5566880 Share on other sites More sharing options...
Doctor Perils Posted July 20, 2020 Share Posted July 20, 2020 @coolbeans - with so many magnets, could there be problems if you're flying with your minis? I don't think so. I knew someone who routinely air-travelled with his army, and he used magnet cases. The most of an "issue" is he needed to pre-check his baggage for it, or if he couldn't inform the crew there that the case has a load of magnets in it, which might cause issues with scanning. Funny anecdote about that: Apparently one time one of the TSA people didn't believe him, put the magnet case through the scanner, and all the magnets caused the scanner to not even work. Like, the scan of his case just had a blank void in it :lol: Ha! Bet they loved that [/sarcasm+worried emojiface] Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5566893 Share on other sites More sharing options...
Bung Posted July 20, 2020 Share Posted July 20, 2020 I love rge Shapeshifter System of Phobos Foundry. No foam, no magnets and alot of minis in a small space. https://www.phobosfoundry.com/ Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5566910 Share on other sites More sharing options...
templargdt Posted July 20, 2020 Share Posted July 20, 2020 I love rge Shapeshifter System of Phobos Foundry. No foam, no magnets and alot of minis in a small space. https://www.phobosfoundry.com/ This looks really great, too bad they are not currently in production Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5566935 Share on other sites More sharing options...
templargdt Posted July 20, 2020 Share Posted July 20, 2020 Are there other types of mini cases like this? Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5566943 Share on other sites More sharing options...
Bung Posted July 20, 2020 Share Posted July 20, 2020 I love rge Shapeshifter System of Phobos Foundry. No foam, no magnets and alot of minis in a small space. https://www.phobosfoundry.com/ This looks really great, too bad they are not currently in productionMaybe drop an Email. Normaly He is super kind in his replys.Last year when i ordered his cnc mill broke down and until it got fixed He was very clear and open in his messages. Even asking if you want to cancel your order. The only other thing i know is A-Case but thats Magnets again. Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5567072 Share on other sites More sharing options...
Emicus Posted July 20, 2020 Share Posted July 20, 2020 It's not new. Just updated logo? Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5567089 Share on other sites More sharing options...
Subtle Discord Posted July 21, 2020 Share Posted July 21, 2020 I've magnetized my models to avoid breakage. Between Chaos and AdMech there's just too many pointy bits and antenna for me to deal with foam. It's not paint damage, the stuff relentlessly catches and grabs at such details. If weight isn't an issue consider a 'rolling jewelry case' if you want something secure and really rugged. You do need to purchase a selection of modular trays to fit and then devise a metal plate of some sort to sit on the floor of the tray, but foam can also be cut-to-fit if that's preferred. It's the kind of case that takes a bit of investment and effort to bring together but compared to what you get from other solutions it's only a bit more expensive, it's a tank of a case that will take a beating, and the locks keep wandering fingers out of your stuff when your attention is elsewhere. I've got a shorter 15" one right now, but with my growing collection I'm going to be getting a 26" one at some in the near future. Link to comment https://bolterandchainsword.com/topic/365049-thoughts-on-that-new-carry-case-they-are-releasing/#findComment-5567251 Share on other sites More sharing options...
