FAQ to Engine War
New FAQ up to bring our new book into the Indomitus era.
For those at work
UPDATES & ERRATA
Page 36 – Serberys Raiders
Add the following to the end of the Skirmishing Line ability:
‘This unit can only be moved once before the start of each battle.’
*Page 36 – Serberys Raiders, Eye of Serberys
Change the first sentence to read:
‘Each time you select a target for a weapon a model in this unit is
making an attack with, you can ignore the Look Out, Sir rule.’
Page 37 – Pteraxii Sterylizors
Replace the third sentence of the unit description with
the following:
‘The Pteraxii Sterylizor Alpha is equipped with: flechette blaster;
taser goad; pteraxii talons.’
*Page 39 – Skorpius Dunerider, Hover Platform
Delete this ability.
*Page 39 – Skorpius Disintegrator, Hover Platform
Page 40 – Archaeopter Transvector
Add ‘Skitarii’ to this unit’s Faction keyword line.
Page 41 – Archaeopter Stratoraptor
Page 42 – Archaeopter Fusilave
Page 47 – Fabrications of the Artisan
Replace the third bullet point with the following:
‘Enhanced Engine Interfaces: Friendly <Forge World> Vehicle
models within 6” of this Warlord can shoot in a turn in which
they Fell Back.’
*Page 50 – Machine God’s Chosen
Change to read:
‘Each time a Morale test is failed for a unit with this dogma,
until the end of the phase, halve the number of models that
flee that unit due to failed Combat Attrition tests (rounding
fractions down).’
Page 52 – Forge World Canticles of the Omnissiah
Add the following to the end of the first paragraph:
‘When a Forge World canticle from the list below is chanted,
it only affects units from the appropriate <Forge World>. For
example, your army includes a Warlord model from the Ryza
Forge World. You can replace one Canticle from the Canticles
of the Omnissiah with the Citation in Savagery Canticle.
When this Canticle is chanted, it only affects Ryza units from
your army.’
FAQs
Q: Can the Mechanicus Locum Stratagem be used to give
characters other than your warlord one of the Holy Order
Warlord Traits?
A: No. The Character is only considered your Warlord for the
purposes of the Warlord Trait itself, not for what Warlord Traits
it has access to.
Q. Does the Panegyric Procession Canticle allow a transuranic
arquebus to be fired after moving?
A: No.
Q: Is the Thunderfire Cannon’s Operated Artillery ability
considered an aura ability for the purposes of the Electro-filament
Countermeasures Stratagem?
A: No.
Q: Can the Tactica Obliqua Stratagem be used if the unit in
question could not fire overwatch due to an ability, psychic
power, etc?
A: Yes.
Q: Can Pteraxii Skystalker and Pteraxii Sterylizor models embark
upon a Skorpius Dunerider?
A: Yes.
Q: When using the Arc Grenade Cluster ability for a unit of
Pteraxii Skystalkers, is the number of D6 rolled equal to the
number of models in that Pteraxii Skystalkers unit?
A: Yes.
Q: If the Luminescent Blessing Canticle of the Omnissiah is in
effect, are affected models with an invulnerable save that is better
than 4+ (such as Fulgurite Electro-Priests under the effect of
their Siphoned Vigour ability) affected, effectively reducing their
invulnerable save to 4+?
A: No.
https://bolterandchainsword.com/topic/365482-faq-to-engine-war/
Going over the items:
1. Who was arguing moving more than once oO
3. Nevewr noticed the Alpha missing the talons.
4+5. I don't know what "Delete this ability" does but I am supper excited!
6+7+8. Missed that one too.
9. Getting a definite, single Forgeworld bias with this update :(
10. Small buff? rounding down now.
11. See 9.
FAQs
1. I think most of us saw this coming.
2. Meh. So close to mobility.
3. Interesting idea. They really need to re-write this ability.
5. WhhY would you? Doesnotcompute... Going to be worse than the London Underground.
6. Clears it up but most kinda knew how it worked.
I think people were stacking the Stygies strat with their built in move.
They did this to all vehicles which had special rules that ignored the penalty for moving and shooting heavy weapons.
FAQs
I thought it was 50-50 considering other factions do the same thing
