Sky Earth True Metallic Metal (SETMM)
Kierdale
I’m sure that most of you know NMM: non-metallic metal. Using paints that aren’t metallic, to make something look metallic. Yellows, browns and creams for gold, for example.
An example I grabbed off Google:
And some may know SENMM: sky earth non metallic metal.
One of the most famous examples, again care of Google:
And there’s simple TMM: True metallic metal. Using metallic paints. Leadbelcher for iron, steel, etc.
I haven’t the time to learn and practise NMM, never mind SENMM, but do use TMM and did recently give SETMM a try: sky-earth true metallic metal.
Now, I’m not saying this is comparable at all to NMM or SENMM, but I think it made the plate look reflective and simply more interesting.
I painted the armour Leadbelcher, shaded it Nuln Oil, and stippled on Stormhost Silver, more on the upper half.
I used Agrax Earthshade to brown the lower half-to-third of the plates, and Guilliman Blue glaze on the upper third/half. Once that was dry I did another dose of each colour to their respective thirds.
A third dose could be done to deepen the blue.
I hope this was, at least, interesting :)
Technique done on a 40k Dark Eldar Medusae body.
Edit: removed AoS images.
Really nice work! SENMM has always stood (to me at least) as visually stunning, but at the same time a little too 'artistic' - even when it's done well, such as in the example you posted, it's clear that it's a painted effect. I like your TMM version better as it's much more subtle and therefore realistic, but still captures the visual effect of making the armour look really reflective.
Thanks for sharing!
  • 4 weeks later...
  • 1 month later...
