chapter master 454 Posted July 29, 2020 Share Posted July 29, 2020 Something I just want to run up the flag pole here for 9th but...you can't weave gunfire as some of us thought and just checking if I was the only one missing this. To Quote: "...then if any other weapons with the same characteristics profile are also being shot at that unit, resolve those attacks before resolving any attacks against the target unit with a weapon that has a different characteristic profile" So this would mean that if you were to run a devastator squad with 4 lascannons and 6 boltguns and were hoping to bait out the storm shield dude from a squad for bolter fire, you cannot. All 4 lascannons must go first then all the boltguns. Naturally, if you bring various different weapons then you can but since the common optimal loadout is often 4 of the same (or just all the same in a unit) this could be a note worthy thing to keep track of. Ofcourse doesn't stop you using a lascannon from a different unit to then lead for the other squad but it isn't possible to alternate guns within one unit alone unless they bring some sort of higherlander set-up of guns. Link to comment https://bolterandchainsword.com/topic/365536-cant-sequence-different-guns-between-each-other/ Share on other sites More sharing options...
Panzer Posted July 29, 2020 Share Posted July 29, 2020 Good to know. Takes away the option to optimize ones shooting on the fly but streamlines things a lot which I think I honestly prefer in this case. Link to comment https://bolterandchainsword.com/topic/365536-cant-sequence-different-guns-between-each-other/#findComment-5573762 Share on other sites More sharing options...
Quixus Posted July 30, 2020 Share Posted July 30, 2020 So this would mean that if you were to run a devastator squad with 4 lascannons and 6 boltguns and were hoping to bait out the storm shield dude from a squad for bolter fire, you cannot. All 4 lascannons must go first then all the boltguns. What stops you from using all six boltguns first? Link to comment https://bolterandchainsword.com/topic/365536-cant-sequence-different-guns-between-each-other/#findComment-5574588 Share on other sites More sharing options...
chapter master 454 Posted July 30, 2020 Author Share Posted July 30, 2020 So this would mean that if you were to run a devastator squad with 4 lascannons and 6 boltguns and were hoping to bait out the storm shield dude from a squad for bolter fire, you cannot. All 4 lascannons must go first then all the boltguns. What stops you from using all six boltguns first? in this example, you want to get rid of the storm shield but they won't roll on him unless needed. It is a fringe example but it is something to be aware of Link to comment https://bolterandchainsword.com/topic/365536-cant-sequence-different-guns-between-each-other/#findComment-5574696 Share on other sites More sharing options...
Dr_Ruminahui Posted July 30, 2020 Share Posted July 30, 2020 Its a bigger deal when you are attacking a unit with multi-wound models with some attacks that do random damage and some that do static damage. For example, as commonly came up for me, a unit of noise marines with sonic blasters (D1) and blastmasters (D D3) attack a unit of destroyers (W 3). Typically I would want to attack with one blastmaster, and then if it doesn't kill a destroyer on its own, enough sonic blasters to finish it off, before going back to the next blastmaster, as that avoids the potential of doing 2 W with one blastmaster and 3 with next, which essentially "wastes" 2 W. That said, I prefer the new method as it speeds things up and means I don't have to explain what I'm doing everytime I do it. Link to comment https://bolterandchainsword.com/topic/365536-cant-sequence-different-guns-between-each-other/#findComment-5574744 Share on other sites More sharing options...
Dam13n Posted July 30, 2020 Share Posted July 30, 2020 Given that the Official Rules portion of this discussion appears to have ended, and you're all now discussing tactics, this is moving to the Tactica sub-forum. Link to comment https://bolterandchainsword.com/topic/365536-cant-sequence-different-guns-between-each-other/#findComment-5574757 Share on other sites More sharing options...
Brother Casman Posted July 30, 2020 Share Posted July 30, 2020 So this would mean that if you were to run a devastator squad with 4 lascannons and 6 boltguns and were hoping to bait out the storm shield dude from a squad for bolter fire, you cannot. All 4 lascannons must go first then all the boltguns.What stops you from using all six boltguns first? in this example, you want to get rid of the storm shield but they won't roll on him unless needed. It is a fringe example but it is something to be aware of Something to keep in mind is that once a model had attacks allocated to it in a given phase, that model has to continue receiving any following attacks in that phase. You might be able to play around with split-firing weapons, too? Link to comment https://bolterandchainsword.com/topic/365536-cant-sequence-different-guns-between-each-other/#findComment-5574770 Share on other sites More sharing options...
Captain Idaho Posted August 29, 2020 Share Posted August 29, 2020 Whilst those Shield Drones in the example can protect the Broadsides from the Lascannons if you fire them first, the best solution in this circumstance is to fire the bolters. If the opponent doesn't want lose a Broadside from Lascannons he is in a real pickle because once he takes all the bolter shots (or even 1) on a Broadside to protect the Drones, the next volley of Lascannons have to at least get him first until next turn. Link to comment https://bolterandchainsword.com/topic/365536-cant-sequence-different-guns-between-each-other/#findComment-5593584 Share on other sites More sharing options...
Jolemai Posted August 29, 2020 Share Posted August 29, 2020 Wouldn't the Drone's special rules override that? Codex > BRB Advanced > Basic Link to comment https://bolterandchainsword.com/topic/365536-cant-sequence-different-guns-between-each-other/#findComment-5593587 Share on other sites More sharing options...
