Khornestar Posted July 29, 2020 Share Posted July 29, 2020 I’m still learning the 9th edition rules, haven’t had time to really read through from A-Z. I’m wondering, is LOS a universal requirement for shooting, or not? There are different terrain rules, for example, and it sounds like for obscuring terrain you can hide behind it and not be targetable even if you’re visible, but if you’re in the terrain, you’re targetable even if you’re not visible/no LOS. Is this correct? Is LOS really not a universal requirement any more for shooting? Not discussing weapons that can indirect fire, so let’s leave them out. Edit: “ to target an enemy unit, at least one model in that unit must be within range (i�e� within the distance of the Range characteristic) of the weapon being used and be visible to the shooting model� ” That’s what makes the terrain rule not make sense. Link to comment https://bolterandchainsword.com/topic/365553-true-los-or-not/ Share on other sites More sharing options...
Ishagu Posted July 29, 2020 Share Posted July 29, 2020 True LoS is still required when the rules permit you to target units. Link to comment https://bolterandchainsword.com/topic/365553-true-los-or-not/#findComment-5574088 Share on other sites More sharing options...
SkimaskMohawk Posted July 29, 2020 Share Posted July 29, 2020 Ya obscuring terrain is the only thing that doesnt follow tlos Link to comment https://bolterandchainsword.com/topic/365553-true-los-or-not/#findComment-5574090 Share on other sites More sharing options...
Fajita Fan Posted July 29, 2020 Share Posted July 29, 2020 I have always preferred using the width of the base to draw a line with a laser pointer to determine arc and the width of the base for height to determine vertical cover. It’s a nice house rule because scenic bases and modeling decisions shouldn’t influence LoS, I’m really surprised they kept this. Link to comment https://bolterandchainsword.com/topic/365553-true-los-or-not/#findComment-5574091 Share on other sites More sharing options...
BluejayJunior Posted July 29, 2020 Share Posted July 29, 2020 Yes, you still have to be able to see the enemy in order to shoot them. Obscuring just makes it so that feature artificially blocks LOS to anything on the other side of it (Titanic, 18W models excepted). Even if the enemy is in Obscuring ruins, you still have to be able to see them to target them. Link to comment https://bolterandchainsword.com/topic/365553-true-los-or-not/#findComment-5574105 Share on other sites More sharing options...
Khornestar Posted July 29, 2020 Author Share Posted July 29, 2020 Ok, then things are more reasonable than I thought. Link to comment https://bolterandchainsword.com/topic/365553-true-los-or-not/#findComment-5574129 Share on other sites More sharing options...
chapter master 454 Posted July 30, 2020 Share Posted July 30, 2020 It is basically ITC "1st floor blocks LoS" but given a concrete rule within the game itself but instead of just the first floor it is instead the whole terrain piece, but it does need to be 5" tall to qualify for this trait (however within your play group, feel free to waive this if you feel it is reasonable...I'm just a fellow frater not a cop :D ) Link to comment https://bolterandchainsword.com/topic/365553-true-los-or-not/#findComment-5574429 Share on other sites More sharing options...
