ValourousHeart Posted July 31, 2020 Share Posted July 31, 2020 With Forgeworld starting to sell models again, how soon do you think until we can order The Lion? I know I'll be getting one, but I'm not sure about the scenic base because I want to field it. But I'm also really nervous because I haven't worked with resin much, and I think this will be my first FW model. Helias_Tancred 1 Back to top Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/ Share on other sites More sharing options...
WrathOfTheLion Posted July 31, 2020 Share Posted July 31, 2020 I think it will be available within a few weeks, since it was shown as 'coming soon' in the article. Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5575496 Share on other sites More sharing options...
Brother-Captain Gilead Posted July 31, 2020 Share Posted July 31, 2020 With Forgeworld starting to sell models again, how soon do you think until we can order The Lion? I know I'll be getting one, but I'm not sure about the scenic base because I want to field it. But I'm also really nervous because I haven't worked with resin much, and I think this will be my first FW model. Â The scenic bases for the primarchs are usually built in a way where the primarch is detachable from the scenic base on a normal base so you can store him in that in your display case and then take him off when you are playing. Isual and WrathOfTheLion 2 Back to top Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5575645 Share on other sites More sharing options...
ValourousHeart Posted July 31, 2020 Author Share Posted July 31, 2020 I have a couple of friends who have picked up some of the other primarchs.  They said that the Russ and Magnus base was kinda like a movement tray, where the models just rest in there, and you can pluck them out for games.  However ones like Guliman and Sangunius have an extra piece on the scenic base that locks the the model in place. They also said if you put a plastic base under the character then they will be to tall to fit into the scenic base. Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5575738 Share on other sites More sharing options...
Gederas Posted August 1, 2020 Share Posted August 1, 2020 I have a couple of friends who have picked up some of the other primarchs.  They said that the Russ and Magnus base was kinda like a movement tray, where the models just rest in there, and you can pluck them out for games.  However ones like Guliman and Sangunius have an extra piece on the scenic base that locks the the model in place. They also said if you put a plastic base under the character then they will be to tall to fit into the scenic base. So, whoever told you that the plastic bases under the character will make them too tall to fit into the scenic base is a dirty liar :lol:  I've built two Primarchs with their full scenic base (technically three, but the Perturabo I have isn't attached to his), and both fit in properly.  I mean.... The 40mm they attach to is designed to slot into their scenic base, so I don't know why it wouldn't work? :lol: Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5575842 Share on other sites More sharing options...
WrathOfTheLion Posted August 1, 2020 Share Posted August 1, 2020 (edited) You should be able to slot the base in, the kit is designed for that. The piece that locks it in is usually magnetized by folks. FW does it this way because the scenic base is not designed for gaming. Â This is what I plan on doing with the Lion kit, since I want to be able to use him with my HH DA. Edited August 1, 2020 by WrathOfTheLion Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5575973 Share on other sites More sharing options...
Chaplain Raeven Posted August 1, 2020 Share Posted August 1, 2020 Â But I'm also really nervous because I haven't worked with resin much, and I think this will be my first FW model. Â Oh man, doing a Primarch as your first FW-model! You're a brave man, good luck! Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5576024 Share on other sites More sharing options...
WrathOfTheLion Posted August 1, 2020 Share Posted August 1, 2020 (edited) Yeah, a Primarch model is a tough one to do as your first FW model, especially if you haven't done resin yet. Perhaps it might be worth it to get something else with the Lion to practice on first? You could grab something like one of the DA praetors. Edited August 1, 2020 by WrathOfTheLion Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5576042 Share on other sites More sharing options...
UtariOnzo Posted August 1, 2020 Share Posted August 1, 2020 The Terninator Praetor was a lot of fun, not too bad a clean up a d pretty forgiving to paint especially with contrast. Highly recommend as a good entry point and companion to the Lion Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5576049 Share on other sites More sharing options...
Chaplain Raeven Posted August 1, 2020 Share Posted August 1, 2020 A contemptor might be a better companion. Closer in size and detail to the Lion than the praetor. You don't gain much experience from the Praetor, that model is way too forgiving to learn the ways of the resin. Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5576068 Share on other sites More sharing options...
Gederas Posted August 1, 2020 Share Posted August 1, 2020 You should be able to slot the base in, the kit is designed for that. The piece that locks it in is usually magnetized by folks. FW does it this way because the scenic base is not designed for gaming. Â This is what I plan on doing with the Lion kit, since I want to be able to use him with my HH DA. I mean... I'm planning on getting two. One for my "Primarchs Display" and one as a gaming model. :yes: Â But I'm also really nervous because I haven't worked with resin much, and I think this will be my first FW model. Oh man, doing a Primarch as your first FW-model! You're a brave man, good luck! Total madlad :lol: Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5576075 Share on other sites More sharing options...
Corswain Posted August 4, 2020 Share Posted August 4, 2020 Don't stress about the resin. My first FW models were Angron and Fulgrim and they weren't a problem. I've since built about a third of the character series and the most difficult part has been interpreting the assembly instructions. You'll be fine! Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5578081 Share on other sites More sharing options...
WrathOfTheLion Posted August 30, 2020 Share Posted August 30, 2020 For an update on this, Lion El'Jonson will be available for order this upcoming Friday, September 4, along with HH Book 9: Crusade. G8Keeper and Cpt. Bannockburn 2 Back to top Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5594058 Share on other sites More sharing options...
G8Keeper Posted August 30, 2020 Share Posted August 30, 2020 It's just a must have for me. What is a DA collection without the Lion? Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5594115 Share on other sites More sharing options...
ValourousHeart Posted August 30, 2020 Author Share Posted August 30, 2020 Thanks for the update? Any word on the interwebs about the price? Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5594118 Share on other sites More sharing options...
Darkwrath121 Posted August 30, 2020 Share Posted August 30, 2020 (edited) Thanks for the update? Any word on the interwebs about the price?To guess based on the other FW primarchs, you're looking at upwards of/around €100/£80/$125. Won't be actual info on prices until preorder on Friday. Forgeworld/30k isn't like GW/40k stuff which has price leaks ahead of time Edited August 30, 2020 by Darkwrath121 Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5594152 Share on other sites More sharing options...
WrathOfTheLion Posted August 31, 2020 Share Posted August 31, 2020 (edited) I will end up getting both the miniature and Crusade for my HH force. Â I assume the price would be around $120-$135. As said, prices don't get posted because other stores don't usually stock FW. Edited August 31, 2020 by WrathOfTheLion Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5594282 Share on other sites More sharing options...
eternal_warrior12 Posted September 3, 2020 Share Posted September 3, 2020 Auto order. No question. Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5595709 Share on other sites More sharing options...
Cpt. Bannockburn Posted September 4, 2020 Share Posted September 4, 2020 Just pre-ordered one. I'm looking forward to painting a bit again. Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5596132 Share on other sites More sharing options...
Grotsmasha Posted September 4, 2020 Share Posted September 4, 2020 Just pre-ordred the Lion and the DA Legion dice.... had to have a purge to afford them, but there's no way I was skipping these. Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5596145 Share on other sites More sharing options...
G8Keeper Posted September 4, 2020 Share Posted September 4, 2020 I'm relegated to it being a Christmas pressy from the wife I think. It's just too much to justify between Indomitus and the new Marine Codex et al. Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5596147 Share on other sites More sharing options...
Brother_Darius Posted September 4, 2020 Share Posted September 4, 2020 a decent hit to the wallet for sure, luckily I took advantage of the voucher deal they were running back in April/May in anticipation of this day. Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5596174 Share on other sites More sharing options...
Interrogator Stobz Posted September 4, 2020 Share Posted September 4, 2020 Anniversary of born date in a few weeks, pre-celebratory pre-order complete. Â Waiting, in the Dark...... Grotsmasha and G8Keeper 2 Back to top Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5596199 Share on other sites More sharing options...
G8Keeper Posted September 4, 2020 Share Posted September 4, 2020 Anniversary of born date in a few weeks, pre-celebratory pre-order complete. Â Waiting, in the Dark...... Â Watching? Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5596203 Share on other sites More sharing options...
Interrogator Stobz Posted September 4, 2020 Share Posted September 4, 2020 ++Of course++ Skywrath, G8Keeper and FarFromSam 3 Back to top Link to comment https://bolterandchainsword.com/topic/365599-forge-world-and-the-lion/#findComment-5596208 Share on other sites More sharing options...
