Montuhotep Posted August 30, 2020 Share Posted August 30, 2020 Quick question - has anyone done an ammo feed for a Knights' RF Battlecannon in the same way as a machine gun belt? If so, how did you do it and do you have any pictures of the finished article? I'm looking for some way to portray more ammo capacity than the box mag in the kit - after all, it's meant to be multiple rounds a time when it fires. Link to comment https://bolterandchainsword.com/topic/366228-ammo-feed-rapid-fire-battlecannon/ Share on other sites More sharing options...
Montuhotep Posted August 31, 2020 Author Share Posted August 31, 2020 That's impressive many thanks. Certainly an idea to use for later! I was actually thinking of a loose chain hanging below the cannon - the spare shells from the Baneblade kit are perfectly sized for this. I have heard of people using .22 shell cases, but given I'm in the UK, they're not so easy to come across. Link to comment https://bolterandchainsword.com/topic/366228-ammo-feed-rapid-fire-battlecannon/#findComment-5594272 Share on other sites More sharing options...
Montuhotep Posted August 31, 2020 Author Share Posted August 31, 2020 Thanks much. I have a total of seven shells, plus Blue Stuff if it comes to that. Link to comment https://bolterandchainsword.com/topic/366228-ammo-feed-rapid-fire-battlecannon/#findComment-5594330 Share on other sites More sharing options...
Fajita Fan Posted August 31, 2020 Share Posted August 31, 2020 IIRC there's as a string of shells on the Stompa kit...if you know someone with an unbuilt one. Using some Ork ammo belts I mocked up doing this on AT scale knights to do something similar. Link to comment https://bolterandchainsword.com/topic/366228-ammo-feed-rapid-fire-battlecannon/#findComment-5594336 Share on other sites More sharing options...
The_Chaplain Posted September 10, 2020 Share Posted September 10, 2020 Fallout hobbies now sell bits-- one of which is a conversion kit for chaos knights with a belt feed for the rapid fire battle cannon. Might be worth a look? Link to comment https://bolterandchainsword.com/topic/366228-ammo-feed-rapid-fire-battlecannon/#findComment-5598844 Share on other sites More sharing options...
