Rogue Posted August 31, 2020 Share Posted August 31, 2020 I'm not much of a hobby/modelling poster, so please forgive me if the following is old hat to everyone else. I've been putting together a ridgerunner for the first time. Now, I like to keep my options open when it comes to vehicles, but magnetising the weapons arm on the back of the ridgerunner looked tricky, and fragile. And needed magnets smaller than the ones I had. So I came up with a different idea. With just a little bit of trimming, you can configure the ridgerunner to switch between the mortar and one of the other options. And if you pick up another weapon arm (or magnetise the top, I guess), you can run to all three. Here's what I did: Stick the two support pieces onto the bed of the ridgerunner. Leave the locator pegs in place. Cut a slot straight downwards from the hole on the weapon (on both sides). This allows the weapon piece to slide down onto the locator pegs. It's a snug fit - this can be held upside down without any movement. Repeat the process with the weapon arm. I've glued on the mining laser, and have picked up another arm for the missile launcher. The pegs provide sufficient grip to stop the arm sagging under the weight of the laser, so it still points forward nice and level. No magnets, not a lot of extra work :) Link to comment https://bolterandchainsword.com/topic/366247-ridgerunner-interchangeable-weapons-no-magnets/ Share on other sites More sharing options...
Fajita Fan Posted September 1, 2020 Share Posted September 1, 2020 I have roughly enough magnets (from my AT stuff and magnetizing all of my bases to sheet metal) to yank a satellite out orbit so I just glue 'em on. The lasers and mortars seem to be the way to go on Ridgerunners so this is a really solid idea for everyone to have more flexiblity. When the model was announced did anyone else Google to see if there was already a Toyota called the Ridgerunner? Link to comment https://bolterandchainsword.com/topic/366247-ridgerunner-interchangeable-weapons-no-magnets/#findComment-5594600 Share on other sites More sharing options...
Xenith Posted September 3, 2020 Share Posted September 3, 2020 When the model was announced did anyone else Google to see if there was already a Toyota called the Ridgerunner? heh, knowing the Toyota's prevalence within the modern mining industry, modelling the ridgerunner on one is a natural next step for a mining themed army. Also, great tutorial, I like it when it's easy. Link to comment https://bolterandchainsword.com/topic/366247-ridgerunner-interchangeable-weapons-no-magnets/#findComment-5595777 Share on other sites More sharing options...
Rogue Posted September 14, 2020 Author Share Posted September 14, 2020 And here's how it looks painted up: Link to comment https://bolterandchainsword.com/topic/366247-ridgerunner-interchangeable-weapons-no-magnets/#findComment-5601272 Share on other sites More sharing options...
Axineton Posted November 6, 2020 Share Posted November 6, 2020 Excellent stuff here Rogue. I’ll be using this suggestion Link to comment https://bolterandchainsword.com/topic/366247-ridgerunner-interchangeable-weapons-no-magnets/#findComment-5628336 Share on other sites More sharing options...
