Bring back the weapon TEMPLATES (ok maybe not, but?)
aknorthroader
I was of the opinion that Flamers (and associated weapons) should have just hit all enemy models in range (in the target unit, of course), with the trade-off being that their range was fairly short. Alas, GW seems to have decided otherwise.
The Spear of the Void Dragon offers an example of how it could have been.
So after a little bit of gaming this weekend, I realized one of the things that was nagging me about blast weapons was the order of operations for determining number of hits.
When you are talking about a blast weapon, it typically only has one shot, but can affect multiple models.  Under previous rules from times past, you would roll to hit and then move the marker, count the number of models that were hit, 4+ for partials and then roll to wound.
Now the rules are roll for the number of shots, then roll to hit, then roll to wound.  I put forth that the first two are backwards.  The Earthshaker cannon, grenade launchers and plasma cannons didn't suddenly turn gatling, so why are we treating them as such?  It should still be a single roll to hit, then roll to see how many were affected, then roll to wound...  as flamers are auto-hit, you are only rolling to see how many were affected then rolling to wound.
This is exacly the issue you had in the first post, and one commented on:
http://www.bolterandchainsword.com/topic/366647-bring-back-the-weapon-templates-ok-maybe-not-but/?p=5606028
If you assume that the blast weapon always hits it's target, then you roll to see how many models in the target unit got hit by the blast, it makes more sense. Rememembe that it's a game, not a simulation, so some abstraction is needed.
So an interesting thing i saw in another game system when it came to template weapons like flamethrowers,  and ordinance that would make them more viable without using templates (with adjusted points for how effective they would become). a roll to hit and success  hits everybody in the unit, roll to wound as normal.
I think that has too much variance. Either hit no one or everyone (and depending on unit size that could be a lot) seems like a big swing to me.
