Dr_Ruminahui Posted October 9, 2020 Share Posted October 9, 2020 Anybody here magnetized a predator turret to accept both the twin-lascannon and the predator autocannon? Wondering what the best way of doing it is. Link to comment https://bolterandchainsword.com/topic/366937-magnetizing-a-predator-turret/ Share on other sites More sharing options...
Doom Herald Posted October 10, 2020 Share Posted October 10, 2020 I haven't done it personally, but from looking at the assembly guide, I would probably do it by magnetizing the top and bottom pieces of the turret to each other. That way, I could open the whole thing up and swap in and out the weapon. The protruding part of the weapons that go inside the turret look like they should hold in place when the whole thing is sealed. If not, you could put magnets inside the turret then embed magnets where the protruding portion was. The first method would need less magnets, but the second would make for a simpler swap. Edit: Here's a youtube video of someone magnetizing the options using bolts in part. I never would have thought of that. Link to comment https://bolterandchainsword.com/topic/366937-magnetizing-a-predator-turret/#findComment-5615039 Share on other sites More sharing options...
Cheex Posted October 10, 2020 Share Posted October 10, 2020 I've done it on all three of my Predators. It wasn't hard, and helps that the weapons are mounted in the turret in such a way that they can pivot up and down, so you can just reuse those holes for the magnets. I used 3mm x 1mm magnets, if that helps. Link to comment https://bolterandchainsword.com/topic/366937-magnetizing-a-predator-turret/#findComment-5615074 Share on other sites More sharing options...
Dr_Ruminahui Posted October 10, 2020 Author Share Posted October 10, 2020 That looks really nice. How much problem do you have with barrel droop? I know that's a common problem even without magnetizing them, and I would think it would be even worse with magnets. Link to comment https://bolterandchainsword.com/topic/366937-magnetizing-a-predator-turret/#findComment-5615081 Share on other sites More sharing options...
Cheex Posted October 10, 2020 Share Posted October 10, 2020 Ah yep, forgot about that. I solved that problem with a thin strip of plasticard under the weapon that limits how far downwards the weapon can point. Link to comment https://bolterandchainsword.com/topic/366937-magnetizing-a-predator-turret/#findComment-5615092 Share on other sites More sharing options...
Dr_Ruminahui Posted October 11, 2020 Author Share Posted October 11, 2020 I ended up taking your advice, Cheex, and have now magnetized my turret. Think I may need to thicken my strip on plasticard - my barrels aren't drooping now, but they may with time. Thanks for the help, everyone. If anyone is interested, you can see the completed (but unpainted) project here: http://www.bolterandchainsword.com/topic/346143-the-judgment-on-kadeth-dr-ruminahuis-emperors-children/?p=5615994 Link to comment https://bolterandchainsword.com/topic/366937-magnetizing-a-predator-turret/#findComment-5615518 Share on other sites More sharing options...
MaliGn Posted October 14, 2020 Share Posted October 14, 2020 I like the way you've added trim round the turret. Link to comment https://bolterandchainsword.com/topic/366937-magnetizing-a-predator-turret/#findComment-5617663 Share on other sites More sharing options...
