Daemon Prince Marbas Posted October 15, 2020 Share Posted October 15, 2020 I'd like to build a semi competitive Purge army list and was wondering what units best take advantage of the legion trait? Link to comment https://bolterandchainsword.com/topic/367055-the-purge/ Share on other sites More sharing options...
MasterDeath Posted October 15, 2020 Share Posted October 15, 2020 I do not think there is a unit that does not benefit from reroll to wound. You want some ways to guarantee wounds on the units you want to kill, like smites/MW-psipowers, maybe a bolter chaoslord for daemon shell or similar things. Generally shootings works better, but CC also works. Link to comment https://bolterandchainsword.com/topic/367055-the-purge/#findComment-5618095 Share on other sites More sharing options...
McElMcNinja Posted October 15, 2020 Share Posted October 15, 2020 With only Characters, Infantry, Bikers, and Hellbrutes getting the re-roll to hit I like Havocs and Oblitorators. Next up would be anything with plasma, less chance of killing themselves over charging. And don't forget it works in melee as well, beserkers and plague marines with flails. Link to comment https://bolterandchainsword.com/topic/367055-the-purge/#findComment-5618129 Share on other sites More sharing options...
Dr_Ruminahui Posted October 15, 2020 Share Posted October 15, 2020 Interesting - I had thought you couldn't take berzerkes, as the 8th ed FAQ gave each of the 4 vigilus <LEGION>s a specific mark specific - but that bit of the FAQ doesn't appear to have carried over into 9th. (It is in the 9th ed Vigilus Ablaze FAQ). As above, the rerolls are good on everything that can get them... so any list focused on infantry would do well with their LEGION traits. EDIT - looked in the wrong FAQ Link to comment https://bolterandchainsword.com/topic/367055-the-purge/#findComment-5618147 Share on other sites More sharing options...
Kain Mor Posted October 15, 2020 Share Posted October 15, 2020 You’re correct about the berserkers, you can’t take them. Link to comment https://bolterandchainsword.com/topic/367055-the-purge/#findComment-5618154 Share on other sites More sharing options...
Dr_Ruminahui Posted October 15, 2020 Share Posted October 15, 2020 Indeed - I was looking that the wrong FAQ - it is still part of the 9th ed. Vigilus Ablaze FAQ that the Purge is nurgle only. Link to comment https://bolterandchainsword.com/topic/367055-the-purge/#findComment-5618191 Share on other sites More sharing options...
Doom Herald Posted October 15, 2020 Share Posted October 15, 2020 Unless the updated FAQ reworded things, you can use any renegade trait you choose for a warband that is not one of the named warbands. This allows you to have a warband named, let's say, "Warband X". Warband X does not have an associated trait and is therefore free to choose any. Because having the keyword THE PURGE requires NURGLE though, you cannot use the strategem, warlord trait, or relic for the purge as these all require THE PURGE keyword. So, you cannot have THE PURGE Berserkers, but you can have WARBAND X Berserkers that make use of the renegade trait for The Purge. Again, that's unless they reworded the new FAQ so that this is different. Link to comment https://bolterandchainsword.com/topic/367055-the-purge/#findComment-5618281 Share on other sites More sharing options...
McElMcNinja Posted October 15, 2020 Share Posted October 15, 2020 My bad, you can't take beserkers as "Purge". I was thinking of a mixed list I ran with Purge and WE in separate detachments. I would get my beserkers in combat then with the strat shoot into combat to free them up to charge. Link to comment https://bolterandchainsword.com/topic/367055-the-purge/#findComment-5618293 Share on other sites More sharing options...
