Doom Herald Posted October 18, 2020 Share Posted October 18, 2020 I'm working on magnetizing a box of Havocs and a box of CSM with the intent of making the weapons interchangeable between the two unit types. One minor complication I'm having is with power cables being difficult to connect. How important is it to have these cables, really? Lascannons seem like they could reasonably need these cables to function, the Missile Launchers seem like I'm just as well cutting them off. I seem to recall plenty of cases of heavy weapons being picked up or discarded on the battlefield in lore. Weapons with ammo feeds going to the pack might be more necessary, but I think those might connect a little easier. Alternatively, I could just try to throw something together to act as a magazine for the ammo. More on that point, how do people convert heavy weapons from Havocs to function on CSMs? Do you have to take the backpack and sacrifice a Havoc? Link to comment https://bolterandchainsword.com/topic/367100-how-essential-are-power-cables-etc-for-heavy-weapons/ Share on other sites More sharing options...
Closet Skeleton Posted October 18, 2020 Share Posted October 18, 2020 I seem to recall plenty of cases of heavy weapons being picked up or discarded on the battlefield in lore. Havocs don't discard or pick up their weapons, their guns fuse into their bodies. Non-specialist chaos marines might be able to pick up a discarded rocket launcher but for Havocs those cables are symbiotic organs. If you want a chaos marine with a lascannon you basically have to convert the havoc ones so might as well cut off any parts that make it harder to attach. With Chaos you can have units look like whatever. If your Havocs have less cables they might be junior Havocs who haven't had time to develope a close symbiotic relationship with their gun or they might have a wireless telepathic connection. Link to comment https://bolterandchainsword.com/topic/367100-how-essential-are-power-cables-etc-for-heavy-weapons/#findComment-5619178 Share on other sites More sharing options...
Paturabo Posted October 18, 2020 Share Posted October 18, 2020 While arms and backpacks are made to be interchangeable between the two kits you might run into some problems because the heavy weapons were made to match up with a specific backpack bit, especially the ones that are carried over the shoulder like the lascannons and rocket launchers which replace the right vent/stabilizer thing. For the heavy bolters/autocannons/reaper chaincannon, if you replace their ammo belt with a large magazine you should be able to get away with giving the models regular backpacks and just magnetising the arms for weapon swaps. Sure they might not have extra ammo but many warbands are forced to scavenge from the battlefield. For the life of mine, I couldn't tell the difference between a havoc and a csm if they're wielding the same weapons, heavy or not. I believe he just wants to move the heavy weapons back and forth. Havocs are now T5 and modeled noticeably larger than regular CSM with larger bases. Link to comment https://bolterandchainsword.com/topic/367100-how-essential-are-power-cables-etc-for-heavy-weapons/#findComment-5619180 Share on other sites More sharing options...
Paturabo Posted October 18, 2020 Share Posted October 18, 2020 Honestly with a little creativity, time, and care you can try to model the lascannons and missile launchers to be held like some of their heresy era counterparts and completely circumvent the need to be modeled connected to a specific backpack. Link to comment https://bolterandchainsword.com/topic/367100-how-essential-are-power-cables-etc-for-heavy-weapons/#findComment-5619181 Share on other sites More sharing options...
MegaVolt87 Posted October 18, 2020 Share Posted October 18, 2020 Just magnatize the bases would be easier. Link to comment https://bolterandchainsword.com/topic/367100-how-essential-are-power-cables-etc-for-heavy-weapons/#findComment-5619236 Share on other sites More sharing options...
Doom Herald Posted October 18, 2020 Author Share Posted October 18, 2020 Paturabo is correct, I want to move the heavy weapons back and forth between the two units. Havocs are noticeably Havocs and not CSM in the current miniature line, they are larger and have additional armor plating, so I wouldn't want to just swap the base sizes. I will probably try assembling the whole weapon system (arms and pack) into a single piece and see how that works. I am a little worried about how fragile this assembly might be though. Any advice on getting an especially strong connection point on the cables/ammo feeds so I can make them into a sturdy single assembly? On the note of the cables, there are still cables connecting the Havoc helmet directly into the weapons without going through the backpack. Since the Missile Launcher seems like the weapon I will use most in CSM squads, I might just cut the cables from them and let the helmet to weapon connect be adequate and maybe be given to the "junior" Havoc when I do outfit them with a Missile Launchers. Link to comment https://bolterandchainsword.com/topic/367100-how-essential-are-power-cables-etc-for-heavy-weapons/#findComment-5619281 Share on other sites More sharing options...
MegaVolt87 Posted October 18, 2020 Share Posted October 18, 2020 One dude in 5 or 10+ thats just slightly larger isn't much of a big deal. As long as the base is correct its not really an issue IMO. If you were putting a new havoc in the older CSM or mk III-IV squads, then yes it would be super noticeable. Link to comment https://bolterandchainsword.com/topic/367100-how-essential-are-power-cables-etc-for-heavy-weapons/#findComment-5619452 Share on other sites More sharing options...
Squike Posted October 23, 2020 Share Posted October 23, 2020 I just picked up some extra havoc heavy weapon bits from ebay to make the regular heavy marines I wanted if I didn't have the havoc bits left over. If you want to stay with the swap method I think the main body as a separate piece is probably best, you could even have the back pack separate to the weapon and arms if that makes the setup less fragile. Link to comment https://bolterandchainsword.com/topic/367100-how-essential-are-power-cables-etc-for-heavy-weapons/#findComment-5621389 Share on other sites More sharing options...
Xenith Posted October 23, 2020 Share Posted October 23, 2020 With the SM Dev squad, you can actually glue gun+arms + backpack together, then replace the back nubbin with a magnet and you instantly have slot on interchangebale weapons - I dont know if the Havoc kit is similar in that respect? From the looks of that RCC model, I think you could do it for sure. The shoulder weapons might need more creativity then. Link to comment https://bolterandchainsword.com/topic/367100-how-essential-are-power-cables-etc-for-heavy-weapons/#findComment-5621401 Share on other sites More sharing options...
