jimbo1701 Posted October 25, 2020 Share Posted October 25, 2020 Hi all. We know legends was clearly stated as not being updated at any point, but as well as them now being quite different to the new points structure, there are several units in there that are now in an odd place due to the changes to firstborn wounds. The ones that spring to mind are veterans on bikes and legion of the damned, both of which are now a wound down. It is most likely futile but I wondered If there was any merit in a community petition to ask GW to give the legends pdf one last glance to bring it in line with such a sweeping change before letting it rest. Conceivably a small amount of someone’s time could make these units valid for another edition. Thoughts? Link to comment https://bolterandchainsword.com/topic/367229-legends-petition-units-left-behind/ Share on other sites More sharing options...
Slave to Darkness Posted October 25, 2020 Share Posted October 25, 2020 Sounds like a good idea. Link to comment https://bolterandchainsword.com/topic/367229-legends-petition-units-left-behind/#findComment-5622058 Share on other sites More sharing options...
Rik Lightstar Posted October 25, 2020 Share Posted October 25, 2020 I'd suspect that IF they were going to do this at all it'd have to wait until ALL the Astartes factions have their Codex. We know that DeathGuard are coming soon but there's also Chaos, Thousand Sons and Grey Knights for sure to be brought in line. Otherwise you'll end up with weird things where Legends units get the boost before the stuff that's still in production. Rik Link to comment https://bolterandchainsword.com/topic/367229-legends-petition-units-left-behind/#findComment-5622078 Share on other sites More sharing options...
Sky Potato Posted October 25, 2020 Share Posted October 25, 2020 Giving the Legends .pdf a bump at the start of every new edition definitely isn’t a bad shout - I doubt it’ll happen though. Link to comment https://bolterandchainsword.com/topic/367229-legends-petition-units-left-behind/#findComment-5622106 Share on other sites More sharing options...
BLACK BLŒ FLY Posted October 25, 2020 Share Posted October 25, 2020 If they update one unit then they have to update them all... so I doubt it. Link to comment https://bolterandchainsword.com/topic/367229-legends-petition-units-left-behind/#findComment-5622117 Share on other sites More sharing options...
Brother Tyler Posted October 25, 2020 Share Posted October 25, 2020 It wouldn't hurt to ask GW to update the Legends files to bring them in line with the 9th edition changes. And if they don't, we can always conduct a project here at the B&C to provide a homegrown version. Link to comment https://bolterandchainsword.com/topic/367229-legends-petition-units-left-behind/#findComment-5622129 Share on other sites More sharing options...
Noserenda Posted October 25, 2020 Share Posted October 25, 2020 Ill bet a bunch of stuff is being added to legends by the Forgeworld book so we might see an update sweep then? Of course that might be just in time for 10th at this rate :D Link to comment https://bolterandchainsword.com/topic/367229-legends-petition-units-left-behind/#findComment-5622134 Share on other sites More sharing options...
Brother Tyler Posted October 26, 2020 Share Posted October 26, 2020 Today's Warhammer Community article has the following bit at the bottom: * If a unit exists but doesn’t have a datasheet in this book, don’t worry! It will be getting a Warhammer Legends datasheet so that you can continue to use it in your games. Some of the units that will be left out of the new compendium are [Chaos] Space Marines. If we assume that those will be in line with their 9th edition peers, it seems reasonable to think that their Legends predecessors should be similarly in line. For this to pan out, though, GW-proper (not just the FW portion) would have to be on board, but it gives a glimmer of hope that we might see an update to the Legends. A faint glimmer - maybe just a mote. Link to comment https://bolterandchainsword.com/topic/367229-legends-petition-units-left-behind/#findComment-5622852 Share on other sites More sharing options...
Xenith Posted October 28, 2020 Share Posted October 28, 2020 It wouldn't hurt to ask GW to update the Legends files to bring them in line with the 9th edition changes. It would be effort from them, however they did just release a massive bunch of PDF's, some of which have a 1 month lifespan, I think 5 go out of date by Jan? I'd ask for the land raider excelsior back. It's still an in-production model, after all. Seems pointless to have a WHW exclusive model that has no usable rules. Link to comment https://bolterandchainsword.com/topic/367229-legends-petition-units-left-behind/#findComment-5623936 Share on other sites More sharing options...
Debauchery101 Posted October 28, 2020 Share Posted October 28, 2020 RIP lias Issodon Link to comment https://bolterandchainsword.com/topic/367229-legends-petition-units-left-behind/#findComment-5624247 Share on other sites More sharing options...
