Squike Posted October 26, 2020 Share Posted October 26, 2020 Hi all, so a question that came up in my latest game. My Titan Legion vs a friends Knight House. 1 of my Reavers is in combat with 2 x Cerastus Knights, my Reavers chainfist fails miserably to kill the knights, my Reaver then proceeds to take catastrophic damage and I roll a D10 to see the result. I roll a 10 so proceed with the Catastrophic Meltdown. The meltdown is in range of another of my Reavers and 2 more knight banners. Now the wording for Catastrophic Meltdown is as follows: "The Titan is destroyed. Roll a D3 and add the number of holes on the Titan's Plasma Reactor Status Track - each model within that many inches of the Titan before it is removed is hit by the blast. Each unit that is hit suffers D6 hits, bypassing void shields, with a strength equal to the Titan's Scale+1" So my question is, does that mean knights get shield saves because they have Ion shields? The wording on the rule says "bypassing void shields" so I would assume that as it doesn't say "shields" or specify "Ion shields" that knights can still take a shield save against the meltdown? if this is correct, how does that work? like a Titan has just gone nuclear and your stood next/underneath it and your fine, yet the Titan with full shields 7" away takes it straight on the armour.... Link to comment https://bolterandchainsword.com/topic/367258-ion-shields-bypassing-void-shields/ Share on other sites More sharing options...
Gore Crow Posted October 26, 2020 Share Posted October 26, 2020 Yeah the rulebook says they are different, and if a rule specifically refers to void shields, it does not affect ion shields, but if it refers to shield saves it will affect both. Maybe intent was for knights who have downed a titan go from 'definitely going to die in the explosion' to 'only probably going to die in the explosion'. EDIT: Further, that Catastrophic Meltdown wouldn't have allowed an ion shield save for two Cerastus Link to comment https://bolterandchainsword.com/topic/367258-ion-shields-bypassing-void-shields/#findComment-5622654 Share on other sites More sharing options...
Squike Posted October 26, 2020 Author Share Posted October 26, 2020 Yeah the rulebook says they are different, and if a rule specifically refers to void shields, it does not affect ion shields, but if it refers to shield saves it will affect both. Maybe intent was for knights who have downed a titan go from 'definitely going to die in the explosion' to 'only probably going to die in the explosion'. EDIT: Further, that Catastrophic Meltdown wouldn't have allowed an ion shield save for two Cerastus even with the +1 save from the shield gauntlet? Link to comment https://bolterandchainsword.com/topic/367258-ion-shields-bypassing-void-shields/#findComment-5622683 Share on other sites More sharing options...
Mandragola Posted October 26, 2020 Share Posted October 26, 2020 Yeah the rulebook says they are different, and if a rule specifically refers to void shields, it does not affect ion shields, but if it refers to shield saves it will affect both. Maybe intent was for knights who have downed a titan go from 'definitely going to die in the explosion' to 'only probably going to die in the explosion'. EDIT: Further, that Catastrophic Meltdown wouldn't have allowed an ion shield save for two Cerastus even with the +1 save from the shield gauntlet? Yes. It's not a 7+ save that you could improve. It's a "-", which means no save at all. Link to comment https://bolterandchainsword.com/topic/367258-ion-shields-bypassing-void-shields/#findComment-5622724 Share on other sites More sharing options...
