UPDATED LIST FURTHER DOWN THIS PAGE. Keeping for completeness and seeing the list evolution if anyone else has a similar idea or concept in the future.
So I am looking to get this force purchased in one fell swoop. We play fairly tough lists locally but I’ve never really been able to work out mechanicum. Looking for any input at all. One of the other ideas I was floating around was to drop some castellax for some adeusecularis in triaros and a macroarid but I don’t think it really fits the theme.
++ Crusade (Mechanicum: Taghmata Army List) [2,995pts] ++
+ HQ +
Anacharis Scoria [315pts]
. Xanathite Abeyant
Magos Dominus [145pts]: Abeyant, Augury Scanner, Cyber-familiar, Laspistol, Machinator Array, Power axe
+ Elites +
Domitar Class Battle-automata Maniple [175pts]: Domitar Class Battle-automata
+ Troops +
Castellax Class Battle-Automata Maniple (Compulsory) [280pts]: Compulsory, Enhanced Targeting Arrays
. Castellax class Battle-automata: 2x Bolter, Darkfire Cannon, Shock Chargers
Castellax Class Battle-Automata Maniple (Compulsory) [210pts]: Compulsory
. Castellax class Battle-automata: 2x Bolter, Multi-melta, Shock Chargers
. Castellax class Battle-automata: 2x Bolter, Mauler Bolt Cannon, Shock Chargers
+ Fast Attack +
The Homonculex [175pts]: 2x Arlatax Power Claw With Inbuilt Cannon
Vorax Class Battle-automata Maniple [270pts]: Bio-corrosive ammunition, Enhanced Targeting Arrays
. Vorax Class Battle-automata: Lightning Gun
Vultarax Stratos-automata Maniple [370pts]: Blessed Autosimulacra, Vultarax Stratos-automata, Vultarax Stratos-automata
+ Heavy Support +
Thanatar Class Siege-automata Maniple [300pts]: Enhanced Targeting Array, Paragon of Metal, Thanatar Class Siege-automata
Thanatar Class Siege-automata Maniple [265pts]: Enhanced Targeting Array, Thanatar Class Siege-automata
+ Allegiance +
Allegiance: Traitor
Legio: Legio Cybernetica
+ Use Playtest Rules +
Use Playtest Rules Errata 1.0 (From FAQ 1.1 Feb/2019): Playtest Rules Errata 1.0 On
+ Mournival Rules +
Mournival Rules
++ Total: [2,995pts] ++
Created with BattleScribe (https://battlescribe.net)
Edited by The Dr
https://bolterandchainsword.com/topic/367273-traitorous-cybernetica/
At, you have no scoring units at all so I would say swap the vorax (they die to a strong wind) or a unit of castallax, for either tech thralls or thallax, thallax would fit your theme better but are expensive themselves , thralls don’t fit the theme as well but are cheaper and could be converted into clock work men to suit it abit more.
The list looks pretty good, although I don't think the single domitar will give you much mileage on the table, I would suggest dropping it and taking a bigger unit of vorax. You have 2 units of darkfire castellax and 2 thanatars, which is quite a bit of long range firepower, I would consider dropping 1 thanatar and making your mauler cannon castellax units bigger, they are going to be the core of the army driving forwards with Scoria. I would also swap the multi-melta castellax for mauler bolt cannons. Dropping 1 thanatar also means you have fewer backfield units to babysit with the magos dominus. You could also make the magos dominus much cheaper, his primary function will be to give cortex control to the darkfire castellax.
Edited by Varyn
The list looks quite similar to my regular 3k list, although I tend to group the Castellax into two larger squads typically - and you might want to consider that, or split into three units instead of four. I tend to think that makes them more survivable (and they're already tough!) - but I appreciate you might want more flexibility in running with smaller units. I also tend to run an additional Magos - to deny potential bonus VPs and for healing purposes - but it's a reasonable investment to make them 'tough', and I'm not sure their damage output will always match up to what they'd cost or typically accompany (either Castellax or Thanatars, in most cases). May just be something to consider!
As others have pointed out, you'd ideally want scoring units - whether in the form of Thralls or Thallax. Either can work well depending on whether you're wanting to stick with the theme (or fit them within that) - but it probably adds further versatility rather than relying on denying the opponent scoring instead. I've mixed and matched before - so this might be to taste or what you envisage their role being.
You might find the Domitar or Vorax easiest to swap to accommodate any changes you might wish to make - again, as others have mentioned - although Vorax are solid against certain lists (Troop-heavy potentially), and the Domitar could 'partner' the Homonculex, so this may just fit within your theme too. You may also consider looking to run the Vulturax individually rather than paired for versatility.
Either way - it's a great theme, and have fun trying out different variations!
Thanks everyone for the feedback, I’ve adjusted a little and tried to take on board the feedback and came up with this. I added an extra dominus but thought keeping on with the array would be useful for battle repairs. I really like thallax but I’m not sure what the best load out would be to support here. Figured a second wave rending assault might be best but I’m just theory hammering here.
Unsure about the castallax composition but keen to see how bigger squads go.
Figured two big thralls should cover obj missions easy enough and I’m sure there can be some conversion to represent the pure thought upgrade. I was keen on the vorax but it seems they might be a little underwhelming so thought the ursarax might be a bit of fun instead.
Seperate the vultarax and added a third thanatar because I clearly hate having friends. Don’t think there’s much more to say on that.
++ Crusade (Mechanicum: Taghmata Army List) [3,000pts] ++
+ HQ +
. Xanathite Abeyant
Magos Dominus [105pts]: Augury Scanner, Laspistol, Machinator Array, Power axe
Magos Dominus [80pts]: Augury Scanner, Laspistol, Power axe
+ Troops +
Adsecularis Covenant [80pts]: Las-lock, 20x Tech-thrall, The Rite of Pure Thought
Castellax Class Battle-Automata Maniple (Compulsory) [315pts]: Compulsory
Thallax Cohort [240pts]: Ferrox, 5x Thallax
+ Fast Attack +
Ursarax Cohort [305pts]: 2x Lightning Claws, 3x Power Fist, 5x Ursarax
Vultarax Stratos-automata Maniple [185pts]: Blessed Autosimulacra, Vultarax Stratos-automata
+ Heavy Support +
+ Allegiance +
Allegiance: Traitor
+ Mournival Rules +
Mournival Rules
++ Total: [3,000pts] ++
Like the new list it has a lot of power but can hold objectives to, ive never used ursarax so can’t comment on them, if you can I would recommend trying to convert on on the thanatars into a cynis, with the double shot, 8 blast plasma shots will ruin anyone’s day even if it is short range.
Register a new account
Sign in
