choppyred Posted October 28, 2020 Share Posted October 28, 2020 Which legion is best for fielding robots? Iron Hands? Iron Warriors or Dark Angels with their men of iron? Link to comment https://bolterandchainsword.com/topic/367321-cybernetica/ Share on other sites More sharing options...
Brofist Posted October 28, 2020 Share Posted October 28, 2020 It depends on what you want to do, tbh. Iron Hands and Iron Warriors have easier access to cortex controllers, but you might consider, say, Alpha Legion or Sons of Horus for the LA rules you could stack onto some robots with an attached Praevian. Spagunk 1 Back to top Link to comment https://bolterandchainsword.com/topic/367321-cybernetica/#findComment-5624214 Share on other sites More sharing options...
GodEmperorOfMankind Posted October 29, 2020 Share Posted October 29, 2020 Are you talking from a rules or fluff perspective? Link to comment https://bolterandchainsword.com/topic/367321-cybernetica/#findComment-5624401 Share on other sites More sharing options...
Cadmus Tyro Posted October 29, 2020 Share Posted October 29, 2020 Iron hands, although I’m a little biased. Head of the Gorgon RoW gives you access to battle automata in your elites slot. So you can field up to four units of: castellax, vorax, domitar, arlatax. Also, remember that every cortex controller allows you to place a unit of thallax or castellax in your heavy support. However, the issue for the IH is their lack of a Cortex controller on a HQ option with “master of the legion” (apart from Autek morr). This means in order to run the RoW and to retain control of your bots you either have to run Autek or multiple HQs (unless you want a Techmarine running around). You could run them without cortex control, you loose the ability to run and to sweep you opponent, which can be irritating. You maybe better served running a cybernetica Allied detachment. You can get access to thanatars at this point as well as getting initiative bonuses and extended cortex control, with the ability to attach your HQ to a unit of monstrous creatures. Hope that helps! Cadmus choppyred and Varyn 2 Back to top Link to comment https://bolterandchainsword.com/topic/367321-cybernetica/#findComment-5624437 Share on other sites More sharing options...
Chaeron Posted October 29, 2020 Share Posted October 29, 2020 Another aspect to consider is what you want the robots themselves to do: are you looking to plug a gap in your list (that another unit doesn't do as well), or is this perhaps for theme and variety? Either is viable of course - but this might also be influential in considerations of what works 'best' just as much as how easy it is to access them. I've played against lists that included them (from memory, Raven Guard and Salamanders), so there's at least scope for including them in a range of Legions! Link to comment https://bolterandchainsword.com/topic/367321-cybernetica/#findComment-5624602 Share on other sites More sharing options...
