gaurdian31 Posted October 30, 2020 Share Posted October 30, 2020 So the C'tan shard that comes with the Obelisk is only on a 40 mm flying base correct? Does that seem small to anyone else? Nightbringer and the Deceiver are only on 40mm as well, where as the Void Dragon is on an 80mm base. Do you think the other C'tan will follow or should I just leave my shard and Nightbringer on the tiny bases so I don't get called out for modelling for advantage? Link to comment https://bolterandchainsword.com/topic/367348-ctan-shard-base-size/ Share on other sites More sharing options...
Shas Oh Dear Posted October 30, 2020 Share Posted October 30, 2020 Afaik the transcendent has always been a 60mm (technically a 56mm flight) base. Interesting that the void dragon is even larger. That's 3 different base sizes depending on model. Link to comment https://bolterandchainsword.com/topic/367348-ctan-shard-base-size/#findComment-5625148 Share on other sites More sharing options...
Mr4Minutes Posted October 30, 2020 Share Posted October 30, 2020 My Deceiver is on the base he came with. Including the crawling warriors. I don’t plan on rebasing him. Unless GW repackages the model with a larger base. Link to comment https://bolterandchainsword.com/topic/367348-ctan-shard-base-size/#findComment-5625182 Share on other sites More sharing options...
gaurdian31 Posted October 30, 2020 Author Share Posted October 30, 2020 Afaik the transcendent has always been a 60mm (technically a 56mm flight) base. Interesting that the void dragon is even larger. That's 3 different base sizes depending on model. Didn't even realize, but you are right, that base is a little bigger. I put mine on a 40mm as I don't like the flying bases and it was the same size as the Nightbringer. Mr4Minutes: I get where you are coming from, I just like adding things like dead marines to my bases so the bigger size works better for that. Link to comment https://bolterandchainsword.com/topic/367348-ctan-shard-base-size/#findComment-5625212 Share on other sites More sharing options...
Mr4Minutes Posted October 31, 2020 Share Posted October 31, 2020 Ahh, gotcha. In that case I’d say base him how you like. I wouldn’t go bigger then the VD 80, but I think anything in between would be fine if it was for aesthetic reasons. Link to comment https://bolterandchainsword.com/topic/367348-ctan-shard-base-size/#findComment-5625586 Share on other sites More sharing options...
Khulu Posted November 14, 2020 Share Posted November 14, 2020 Sorry I'm late to the party, but Void Dragon is MASSIVELY larger than Deceiver or Nightbringer. I don't think they'd put either one of those on an 80mm base without a new model. Link to comment https://bolterandchainsword.com/topic/367348-ctan-shard-base-size/#findComment-5631264 Share on other sites More sharing options...
gaurdian31 Posted November 30, 2020 Author Share Posted November 30, 2020 I assume that is the same in regards to the C'tan shard from the obelisk as well? Link to comment https://bolterandchainsword.com/topic/367348-ctan-shard-base-size/#findComment-5638194 Share on other sites More sharing options...
