Mcha0s92 Posted November 17, 2020 Share Posted November 17, 2020 Hey guys a quick question is it possible in an indomitor kill team of 10 heavy intercessor armed with executor bolt rifle to give the heavy executor rifle to 2 of them like in the normal datasheet of the heavy intercessor or do we have some restriction? And same question for the spectrus kill team is it possible to give comms array or helix gauntlet to infiltrators? I see no option in the kill team page in the codex that is why im asking. Link to comment https://bolterandchainsword.com/topic/367718-kill-team-options/ Share on other sites More sharing options...
Debauchery101 Posted November 17, 2020 Share Posted November 17, 2020 You have the same loadout options/restrictions Link to comment https://bolterandchainsword.com/topic/367718-kill-team-options/#findComment-5632499 Share on other sites More sharing options...
Mcha0s92 Posted November 17, 2020 Author Share Posted November 17, 2020 You have the same loadout options/restrictionsOk i guess i can then,thank you Link to comment https://bolterandchainsword.com/topic/367718-kill-team-options/#findComment-5632519 Share on other sites More sharing options...
MagicHat Posted November 17, 2020 Share Posted November 17, 2020 It is on page 51, creating kill teams, under wargear section. Link to comment https://bolterandchainsword.com/topic/367718-kill-team-options/#findComment-5632546 Share on other sites More sharing options...
m_r_parker Posted November 17, 2020 Share Posted November 17, 2020 Page 51 of the Supplement (i.e. the page before the 4 Kill Team types are listed): WARGEAR A model included in a Kill Team unit can be equipped with any of the warmer listed for that model under the warmer options on it's original data sheet. For the purposes of wargear options, any option that requires a minimum number of models in the unit will require that number of models of that type to be included in the unit (e.g. one model can be equipped with an Astartes grenade launcher for every 5 Intercessors or Ontercessor Sergeant in this unit, not for every 5 models of any type) Some confusion may lie when the Kill Team has additional Wargear Options that are different to the core data sheet in the Space Marine codex. Specifically, for Indomitor Kill Teams, it would appear that Heavy Intercessors can have a heterogenous mix of weapons (i.e. different weapon types), whereas the Space Marine codex entry requires them to be homogenous (i.e all weapons of the same type). Also confusingly, the Indomitor Kill Team Wargear Options references 'heavy bolt rifle, 'heavy auto bolt rifle' and 'heavy stalker bolt rifle' - which I believe correspond to ' heavy bolt rifle', 'hellstorm bolt rifle' and 'executor bolt rifle' in the Space Marine codex (one for the FAQ) Link to comment https://bolterandchainsword.com/topic/367718-kill-team-options/#findComment-5632550 Share on other sites More sharing options...
Mcha0s92 Posted November 17, 2020 Author Share Posted November 17, 2020 Page 51 of the Supplement (i.e. the page before the 4 Kill Team types are listed): WARGEAR A model included in a Kill Team unit can be equipped with any of the warmer listed for that model under the warmer options on it's original data sheet. For the purposes of wargear options, any option that requires a minimum number of models in the unit will require that number of models of that type to be included in the unit (e.g. one model can be equipped with an Astartes grenade launcher for every 5 Intercessors or Ontercessor Sergeant in this unit, not for every 5 models of any type) Some confusion may lie when the Kill Team has additional Wargear Options that are different to the core data sheet in the Space Marine codex. Specifically, for Indomitor Kill Teams, it would appear that Heavy Intercessors can have a heterogenous mix of weapons (i.e. different weapon types), whereas the Space Marine codex entry requires them to be homogenous (i.e all weapons of the same type). Also confusingly, the Indomitor Kill Team Wargear Options references 'heavy bolt rifle, 'heavy auto bolt rifle' and 'heavy stalker bolt rifle' - which I believe correspond to ' heavy bolt rifle', 'hellstorm bolt rifle' and 'executor bolt rifle' in the Space Marine codex (one for the FAQ) Thank you very much i found it :) Link to comment https://bolterandchainsword.com/topic/367718-kill-team-options/#findComment-5632569 Share on other sites More sharing options...
