Hey people,
Can you move after veiling? The rule days "in your movement phase", so it's not necessarily over at that point. It also doesn't say anything to the contrary.
Does saying "set back up" is sufficient to imply that these models cannot move anymore? Seems a bit subtle to me...
Mind you, I'm pretty much convinced that the intent is that those units aren't allowed to move after veiling, I just find out weirdly cryptic. It's not reinforcement, disembarking, etc. I don't see anything in the brb that says "a unit can't move if it was set up in this phase".
Thanks!
Edit: Ah, a general FAQ confirmed they cannot move. Nevermind.
Edited by Miek
https://bolterandchainsword.com/topic/367809-move-after-veiling/
I think angrom is right; per the rare rules (page 363 of the rulebook), the unit is considered as having moved only if it arrives as reinforcements - which isn't the case.
Obviously stuff like immovable phalanx and eternal guardians that clearly mention types of move will work after veiling (if the unit didn't move prior), but I guess there are other cases I'm missing where the criteria is more general (i.e.: has not moved). Or were those all removed / rephrased?
Edited by Miek
Register a new account
Sign in
