Keen senses...the melee buff
TiguriusX
I always use keen senses with my shooting units...but the stratagem got a massive melee buff in 9th
Early reviews pointed out we can ignore charge modifiers like the tanglefoot grenade from custodes
I haven't seen much discussion on the melee buff
The ability to ignore hit modifiers in melee means every eligible unit can hit on 2s thanks to our chapter tactic granting +1 to hit
This trick used to be limited to terminators in the old codex using fury of the first
Now you can do it with things like jump wolf guard or TWC wielding THs that hit on 2
https://bolterandchainsword.com/topic/367865-keen-sensesthe-melee-buff/
Don't have my book to hand but what is the exact wording? If it is ignores negative modifiers then what you say about hitting on 2s due to the +1 to hit chapter tactic is amazing. If it just say ignores modifiers to hit, then wouldn't that mean it ignores the chapter tactic of +1?
So BS3+ dudes will hit on a 2+ even with Fists/Hammers with Keen Senses in play? That is crazily good if true.
Use it on your Fangs etc T1 and then your melee units when you get into charge range.
It has to be used in the shooting phase so you only get to buff 1 unit
Also does not improve BS so you need another trick for long fangs. I use the signum + cherub combo or the recitation of focus when I need BS 2 long fangs
Sorry, I meant WS3+ rather than BS3+. OP fixed.
Note to self: Think faster, type slower. :teehee:
Then in response to your corrected question
All WS in our army is basically WS3 to start
So keen senses + our natural combat doctrine giving +1 will transform any eligible unit (infantry/biker/cavalry) into WS2 in the fight phase
I just noticed that nuance in my last reading of the stratagem...I am so accustomed to the OLD rule I never looked at it closely
I personally stopped using jump WG with THs b/c I couldn't get the 2's rerolling...made the swap to LC spam instead
This also helps TWC holding TH/PFs...previously they couldn't get better than 3s
The new and improved keen senses is really really good
