Kaiju Soze Posted November 26, 2020 Share Posted November 26, 2020 I'm working on converting Iron Father Feiros into a Warpsmith for my CSM Renegades army, with the idea of replacing the servo arms with cable-tentacle dendrites. Green stuff for the cables, then adding the claw and cutting torch from the plastic kit. Unfortunately for me, the first attempt to assemble one of the mechatendrils resulted in the green stuff portion drooping and the cutting torch touching the miniature's foot. So that isn't ideal. I'm using the Greenstuffworld Roll Maker for texture, so sculpting around a wire doesn't seem like it would work. I have read that Milliput sets harder than greenstuff, which makes me think it would be better suited for what I'm currently trying. Does this seem right to anyone? And can anyone suggest which type of Milliput would be best (if any) for this? TLDR: Greenstuff cables won't hold weight (even light weight), would Milliput work better? Link to comment https://bolterandchainsword.com/topic/367898-material-for-mechadritetendril-cables/ Share on other sites More sharing options...
Marshal Loss Posted November 26, 2020 Share Posted November 26, 2020 You can get products like these as well; not used any, but heard good things about them Jolemai 1 Back to top Link to comment https://bolterandchainsword.com/topic/367898-material-for-mechadritetendril-cables/#findComment-5636775 Share on other sites More sharing options...
Jolemai Posted November 26, 2020 Share Posted November 26, 2020 That would have been my recommendation too. Need some myself... Link to comment https://bolterandchainsword.com/topic/367898-material-for-mechadritetendril-cables/#findComment-5636776 Share on other sites More sharing options...
pawl Posted November 26, 2020 Share Posted November 26, 2020 I'm working on converting Iron Father Feiros into a Warpsmith for my CSM Renegades army, with the idea of replacing the servo arms with cable-tentacle dendrites. Green stuff for the cables, then adding the claw and cutting torch from the plastic kit. Unfortunately for me, the first attempt to assemble one of the mechatendrils resulted in the green stuff portion drooping and the cutting torch touching the miniature's foot. So that isn't ideal. I'm using the Greenstuffworld Roll Maker for texture, so sculpting around a wire doesn't seem like it would work. I have read that Milliput sets harder than greenstuff, which makes me think it would be better suited for what I'm currently trying. Does this seem right to anyone? And can anyone suggest which type of Milliput would be best (if any) for this? TLDR: Greenstuff cables won't hold weight (even light weight), would Milliput work better? You can actually mix Milliput and Green Stuff to get the best of both worlds - the Milliput allows for fine sculpting, rock hard finish and the ability to sand, while the GS stops the Milliput from being brittle or crumbly. Aside from that I wouldn't consider myself experienced enough to offer any solid advice, I'm afraid. Link to comment https://bolterandchainsword.com/topic/367898-material-for-mechadritetendril-cables/#findComment-5636823 Share on other sites More sharing options...
Firedrake Cordova Posted November 27, 2020 Share Posted November 27, 2020 Slightly left-field, but have you considered using a wound guitar string (E, A, or D)? It would obviously still be a bit flexible, but it's not going to break on you. Link to comment https://bolterandchainsword.com/topic/367898-material-for-mechadritetendril-cables/#findComment-5636895 Share on other sites More sharing options...
Brother_Angelus Posted November 27, 2020 Share Posted November 27, 2020 I used the power cables from the link below to give Inquisitor 54mm figure some additional mechandrites. They're soft enough to bend and shape, but hold weight without snapping or drooping. http://www.dragonforge.com/Painting%20service/for%20sale/sculpting_supplies.htm Link to comment https://bolterandchainsword.com/topic/367898-material-for-mechadritetendril-cables/#findComment-5636901 Share on other sites More sharing options...
apologist Posted November 27, 2020 Share Posted November 27, 2020 You can get products like these as well; not used any, but heard good things about them I can attest to these – Zinge make good product, and their flexible materials are brilliant. It's essentially a wire embedded in some sort of resin. It's flexible, but the material's not rubbery or soft, so the details remain crisp. W.A.Rorie 1 Back to top Link to comment https://bolterandchainsword.com/topic/367898-material-for-mechadritetendril-cables/#findComment-5636911 Share on other sites More sharing options...
sbarnby71 Posted January 13, 2021 Share Posted January 13, 2021 (edited) https://www.zinge.co.uk/collections/poseable-wrapped-wire/products/poseable-wire-wrapped-cable-power-cable-6-various-diameters-1mm-1-3mm-1-5mm-1-7mm-1-9mm-2-4mm Go for these from Zinge, they are wrapped wire, very posable and look like real power cables, I use them to make servo skull attachments. They also sell connector plugs to fit on the ends: Edited January 13, 2021 by sbarnby71 Link to comment https://bolterandchainsword.com/topic/367898-material-for-mechadritetendril-cables/#findComment-5653442 Share on other sites More sharing options...
