FormelyKnownAsSmashyPants Posted November 27, 2020 Share Posted November 27, 2020 Thinking of doing a Tank Coy in 2021 if we end up with new IG models and I’m thinking of using Land Raider tracks on LR Hull. Has anyone done this? And if so is there much work involved? Link to comment https://bolterandchainsword.com/topic/367909-leman-russ-command-tank-tracks/ Share on other sites More sharing options...
Xenith Posted November 27, 2020 Share Posted November 27, 2020 Do you mean using the whole side sections of the Raider, or widening the Russ chassis side panels to accomodate the Raider tracks? FormelyKnownAsSmashyPants 1 Back to top Link to comment https://bolterandchainsword.com/topic/367909-leman-russ-command-tank-tracks/#findComment-5637014 Share on other sites More sharing options...
Ryltar Thamior Posted November 27, 2020 Share Posted November 27, 2020 Looks like it's been done previously on B&C The Land Raider tracks are almost twice as wide as standard Leman Russ tracks, though it looks like it might be surprisingly viable to do with some spacers between the outer and inner hull. Although it might be a little interesting due to the differences in length between the sections for a Land Raider and the places you'd be mounting them on a Russ. FormelyKnownAsSmashyPants 1 Back to top Link to comment https://bolterandchainsword.com/topic/367909-leman-russ-command-tank-tracks/#findComment-5637029 Share on other sites More sharing options...
FormelyKnownAsSmashyPants Posted November 27, 2020 Author Share Posted November 27, 2020 Do you mean using the whole side sections of the Raider, or widening the Russ chassis side panels to accomodate the Raider tracks? The latter, widening the Russ panels to accomodate the Raider tracks. Looks like it's been done previously on B&C The Land Raider tracks are almost twice as wide as standard Leman Russ tracks, though it looks like it might be surprisingly viable to do with some spacers between the outer and inner hull. Although it might be a little interesting due to the differences in length between the sections for a Land Raider and the places you'd be mounting them on a Russ. Thanks for the link, that seems doable with a bit of work. I’ll try and PM Dark Bjoern and see if he’s got some advice. I’ve seen it done the other way with double Russ tracks but I think the other way with the Raider tracks would look better. Ryltar Thamior 1 Back to top Link to comment https://bolterandchainsword.com/topic/367909-leman-russ-command-tank-tracks/#findComment-5637034 Share on other sites More sharing options...
