Sword Brother Adelard Posted December 10, 2020 Share Posted December 10, 2020 Does anyone know of a good colour match for PWF in a range which has dropper bottles?I have a few more knights to paint, and for my sins, went with PWF as the main colour last time. This time however, I own an airbrush, so won't be spending weeks endlessly laying down countless layers of watered down paint to achieve coverage and smoothness. However, I hate using GW pots when airbrushing. (I suppose I could buy a pipette...) Link to comment https://bolterandchainsword.com/topic/368117-pallid-wych-flesh-equivalents/ Share on other sites More sharing options...
Bryan Blaire Posted December 10, 2020 Share Posted December 10, 2020 If no one can get you a dropper bottled equivalent and you don't want something that you have to wash out each time, you can get a batch of small disposable transfer pipettes: https://www.amazon.com/EC2BUY-Transfer-Pipettes-Suitable-Childrens/dp/B06XXP4TQZ/ref=asc_df_B06XXP4TQZ/?tag=hyprod-20&linkCode=df0&hvadid=216559542401&hvpos=&hvnetw=g&hvrand=10143756243574517728&hvpone=&hvptwo=&hvqmt=&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9028226&hvtargid=pla-354323865812&psc=1 You can probably find a larger quantity for about the same price of larger ones, but you'll have to play with any of them to figure out what gives you the right amount for your airbrush. Link to comment https://bolterandchainsword.com/topic/368117-pallid-wych-flesh-equivalents/#findComment-5643055 Share on other sites More sharing options...
Urauloth Posted December 11, 2020 Share Posted December 11, 2020 I would look into getting an empty dropper bottle in the size you ant and putting your PWF in that. I did this with mine just for painting on a wet palette, because I find it an awkward colour to work with and I like being able to shake it properly with an agitator which there's no room for in those nasty little GW flip-tops. Link to comment https://bolterandchainsword.com/topic/368117-pallid-wych-flesh-equivalents/#findComment-5643086 Share on other sites More sharing options...
Firedrake Cordova Posted December 11, 2020 Share Posted December 11, 2020 If you need to thin Pallid Wych Flesh at least 1:1 to get it to run through the airbrush, you could get one of the empty 35ml Vallejo mixing bottles, and pour your pot of of paint into that. Obviously, you'll end up with a load of paint still in the GW pot, so it's a case of put airbrush thinner in it, give it a good shake, then pour that into the mixing bottle (and give that a good shake too). You should be able to get most/all of the paint out of the GW pot, and you'll end up with a bottle of pre-thinned Pallid Wych Flesh, ready for airbrushing. Link to comment https://bolterandchainsword.com/topic/368117-pallid-wych-flesh-equivalents/#findComment-5643252 Share on other sites More sharing options...
Lord Marshal Posted December 11, 2020 Share Posted December 11, 2020 Dragon Tooth from the Army Painter is very close. Silver Grey from Vallejo Model Colour also, albeit a bit lighter. Link to comment https://bolterandchainsword.com/topic/368117-pallid-wych-flesh-equivalents/#findComment-5643444 Share on other sites More sharing options...
Aarik Posted December 11, 2020 Share Posted December 11, 2020 It's really easy to transfer GW paints to dropper bottles. I'd recommend doing that. Link to comment https://bolterandchainsword.com/topic/368117-pallid-wych-flesh-equivalents/#findComment-5643522 Share on other sites More sharing options...
Sword Brother Adelard Posted December 12, 2020 Author Share Posted December 12, 2020 Thanks guys, I think I'll give transferring a try. At least that way I can guarantee colour match. Link to comment https://bolterandchainsword.com/topic/368117-pallid-wych-flesh-equivalents/#findComment-5643658 Share on other sites More sharing options...
DarkMark Posted December 22, 2020 Share Posted December 22, 2020 Scale 75 Pale skin or Vallejo off white 70.820 are both pretty close. Link to comment https://bolterandchainsword.com/topic/368117-pallid-wych-flesh-equivalents/#findComment-5646973 Share on other sites More sharing options...
Sword Brother Adelard Posted December 22, 2020 Author Share Posted December 22, 2020 Thanks all, in the end I went for decanting and it worked reasonably well! Link to comment https://bolterandchainsword.com/topic/368117-pallid-wych-flesh-equivalents/#findComment-5647006 Share on other sites More sharing options...
ShinyRhino Posted December 28, 2020 Share Posted December 28, 2020 For posterity, Leather White from Reaper Master Series is a close match. Link to comment https://bolterandchainsword.com/topic/368117-pallid-wych-flesh-equivalents/#findComment-5648560 Share on other sites More sharing options...
