Chazzmos Posted December 11, 2020 Share Posted December 11, 2020 What do you think is the optimum TWC loadout and size? I haven't run them before 9th, but I'm thinking 4 TWC: 2 x CS/SS, 2 x PF/BP The CS/SS are ablative and chaff, PF is heavy punching but at a good price point. What are you thinking for your TWC in 9th? Link to comment https://bolterandchainsword.com/topic/368120-9th-thunderwolf-cav-loadout-and-squad-size/ Share on other sites More sharing options...
Ragnar69 Posted December 11, 2020 Share Posted December 11, 2020 I think SS for everyone is mandatory, except maybe for a leader with dual frost claws. I would go with a fist on the leader, 1+ chainswords, rest claws as points allow. Squad size 4 or 5. Definitely not 6, coherency would be a PITA and 3 are not enough Link to comment https://bolterandchainsword.com/topic/368120-9th-thunderwolf-cav-loadout-and-squad-size/#findComment-5643206 Share on other sites More sharing options...
Karhedron Posted December 11, 2020 Share Posted December 11, 2020 4-5 seems to be about right. A 3-man squad is too easy to take below effective strength with a couple of failed saves while 6 becomes vulnerable to blast. For the leader I would either go TH/SS or 2 Claws with the Thane Stratagem to make then Frost Claws. For the rest of the squad I would take shields and either single Claws or Fists depending on whether you are planning to mulch infantry or tackle heavier targets. Link to comment https://bolterandchainsword.com/topic/368120-9th-thunderwolf-cav-loadout-and-squad-size/#findComment-5643212 Share on other sites More sharing options...
Chazzmos Posted December 11, 2020 Author Share Posted December 11, 2020 It sounds like SS are the go on all of them. I suppose for 5 points, it makes the model that much more durable. Having claws or fists on them as well pumps their points up quite a bit, but it is a super elite unit. The dual frost claws looks very nasty on the leader, that's a lot of attacks with multiple damage and re-rolling wounds. Makes him good against most things. Link to comment https://bolterandchainsword.com/topic/368120-9th-thunderwolf-cav-loadout-and-squad-size/#findComment-5643239 Share on other sites More sharing options...
Karhedron Posted December 11, 2020 Share Posted December 11, 2020 (edited) To be fair, a single LC is only +5 points but it actually makes the model so much better than a CS. You still get the +1A but gain an extra point of AP as well as rerolls to Wound. Point-for-point they are actually more efficient than Chainswords, even if you are just blending chaff with them. Dual Frost Claws are very nasty indeed. The stat line compares very favourably with Teeth of Terra (which is a very popular relic). Although they have 1 less attack, they reroll wounds which is big, particularly against tough opponents. The other thing to consider when loading out your TWC is what level of character support you intend to provide them. LCs will hit on a 2+ on the charge and can reroll wounds so make for a squad that can operate with minimal support. They just don't need much to help to get stuck in and start killing things. On the other hand, if you are loading out with Fists/Hammers then you might want to consider a Wolf Lord or even Chapter Master. Full rerolls to hit with multiple Hammers/Fists will make a big mess of tough targets. A Thunder Master With Armour Indomintus, Iron Resolve WLT and a SS is one of the tankiest characters in the game. 9W, T5 and 1+/4++/6+++. He is as tough as you can go while still benefiting from LOS. Edited December 11, 2020 by Karhedron Link to comment https://bolterandchainsword.com/topic/368120-9th-thunderwolf-cav-loadout-and-squad-size/#findComment-5643245 Share on other sites More sharing options...
Castle Wolfenstein Posted December 11, 2020 Share Posted December 11, 2020 Armor Indomitus and Pelt of the Balewolf? is there a way to give 2 relics to the same character? Link to comment https://bolterandchainsword.com/topic/368120-9th-thunderwolf-cav-loadout-and-squad-size/#findComment-5643256 Share on other sites More sharing options...
Vassakov Posted December 11, 2020 Share Posted December 11, 2020 I've just finished assembling a five man unit - have gone for 2x Storm Shields and Chainswords, 1 with a Shield and Power Fist and one with a Shield and Thunder Hammer. The Pack Leader has dual Lightning Claws, which will pretty much always be upgraded to Frost Claws. Think this gives a good balance of allowing them to take on all comers, with a couple of ablative wounds in terms of the Chainswords models. Also gives you a tonne of attacks to chop through hordes, whilst still having enough punch to go after elite units. Of course, the fact that I'm backing them up with a Wolf Priest on a bike with MoS, Hunter and the Relic Crozius probably helps there... Link to comment https://bolterandchainsword.com/topic/368120-9th-thunderwolf-cav-loadout-and-squad-size/#findComment-5643257 Share on other sites More sharing options...
Karhedron Posted December 11, 2020 Share Posted December 11, 2020 Armor Indomitus and Pelt of the Balewolf? is there a way to give 2 relics to the same character? Sorry, I am getting muddled up with my other Chapter (Blood Angels) who do have a way to give a Character 2 relics. Wolves can get a 2nd WLT via Warrior of Legend. Even ditching the Pelt, that is a very tanky character. I will amend the OP. Link to comment https://bolterandchainsword.com/topic/368120-9th-thunderwolf-cav-loadout-and-squad-size/#findComment-5643268 Share on other sites More sharing options...
Guest Triszin Posted December 11, 2020 Share Posted December 11, 2020 Armor Indomitus and Pelt of the Balewolf? is there a way to give 2 relics to the same character? No, but saga of the bear + bakewolf makes for a tanky unit Link to comment https://bolterandchainsword.com/topic/368120-9th-thunderwolf-cav-loadout-and-squad-size/#findComment-5643277 Share on other sites More sharing options...
Rune Priest Jbickb Posted December 11, 2020 Share Posted December 11, 2020 Ah bakewolf, the national tart of Fenris (Couldn't resist mate Kallas and One Two Wolf 2 Back to top Link to comment https://bolterandchainsword.com/topic/368120-9th-thunderwolf-cav-loadout-and-squad-size/#findComment-5643298 Share on other sites More sharing options...
Castle Wolfenstein Posted December 11, 2020 Share Posted December 11, 2020 Armor Indomitus and Pelt of the Balewolf? is there a way to give 2 relics to the same character? Sorry, I am getting muddled up with my other Chapter (Blood Angels) who do have a way to give a Character 2 relics. Wolves can get a 2nd WLT via Warrior of Legend. Even ditching the Pelt, that is a very tanky character. I will amend the OP. Dang, I was hoping I missed something and there was a way to give my dual claw WGBL armor of Russ and frost claws. Oh well... Karhedron 1 Back to top Link to comment https://bolterandchainsword.com/topic/368120-9th-thunderwolf-cav-loadout-and-squad-size/#findComment-5643340 Share on other sites More sharing options...
Wolf Guard Dan Posted December 11, 2020 Share Posted December 11, 2020 Using Thane to give frost claws to the pack leader is putting a lot of eggs in one basket. There’s not a lot of things that will stand up to a properly equipped pack anyway. I’ll still likely do it but it depends on what else is in the list. Link to comment https://bolterandchainsword.com/topic/368120-9th-thunderwolf-cav-loadout-and-squad-size/#findComment-5643347 Share on other sites More sharing options...
yan Posted December 12, 2020 Share Posted December 12, 2020 (edited) I still use them as chaff clearing and shield for my army. So i try to keep them s bit cheap since they will die first. Two units of 4 (5if i have the points) with cs and ss and a thunderhammer on the packleader. Quickly rush up the board to grab an objective and hold it till the backup (bloodclaws and wulfen dreads) come to do the real damage. Edited December 12, 2020 by yan Link to comment https://bolterandchainsword.com/topic/368120-9th-thunderwolf-cav-loadout-and-squad-size/#findComment-5643747 Share on other sites More sharing options...
