techsoldaten Posted January 11, 2021 Share Posted January 11, 2021 The latest GW article on the new Deathguard Codex highlights some changes for Mortarion and Deathshroud Terminators. https://www.warhammer-community.com/2021/01/11/7-of-the-most-gruesome-new-rules-for-the-death-guard/ Mortarion: - Now gets 3 Warlord Traits. - Still gets Disgustingly Resilient, reducing incoming damage by 1. - Revoltingly Resilient gives him +1 to save rolls. - Living Plague lets him dish mortal wounds to any unit in 3". - Arch-Contaminator lets him reroll all failed wound rolls. - In addition, he gets to choose another Warlord Trait from Plague Companies. The Droning would allow him to half the movement distance of enemy units. Deathshroud: - Are now WS 2. - Can now move and advance the same as regular Terminators. - Manreapers now have a profile that allows 2 hit rolls per attack. Need to see the points, but this might be the best melee pairing in the game. Move and charge with Mortarion in the first turn, bring in the Deathshroud in the second. Even with the opponent dedicating all of their firepower to destroying Mortarion, the 9+ ablative wounds make him formidable. The fact units can't escape him by moving out of range means 3+ rounds of close combat. This would be devastating to small, elite armies that depend on grabbing objectives to secure victory. The article also says Poxwalkers are getting cheaper, meaning you have ample objective grabbers to boot. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/ Share on other sites More sharing options...
Marshal Loss Posted January 11, 2021 Share Posted January 11, 2021 - Revoltingly Resilient gives him +1 to save rolls. - Living Plague lets him dish mortal wounds to any unit in 3". - Arch-Contaminator lets him reroll all failed wound rolls. None of this is certain yet. These abilities may well have changed (RR definitely will not be the same), and we don't know if Deathshroud have kept their 4++. Points, though, we probably have: check out last week's FAQ. Morty is 490, Deathshroud are 50 each with the Chimes being a single 15pt upgrade. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5652887 Share on other sites More sharing options...
techsoldaten Posted January 11, 2021 Author Share Posted January 11, 2021 - Revoltingly Resilient gives him +1 to save rolls. - Living Plague lets him dish mortal wounds to any unit in 3". - Arch-Contaminator lets him reroll all failed wound rolls. None of this is certain yet. These abilities may well have changed (RR definitely will not be the same), and we don't know if Deathshroud have kept their 4++. Points, though, we probably have: check out last week's FAQ. Morty is 490, Deathshroud are 50 each with the Chimes being a single 15pt upgrade. Thank you for pointing out the fact I may be getting ahead of myself. Never assume GW will keep anything but the name of special abilities! Assuming there's some utility to those warlord traits, it does seem like game designers have given some thought to the main issues for Morty and Deathshroud Terminators: survivability and movement. It's encouraging. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5652892 Share on other sites More sharing options...
Hathor42 Posted January 11, 2021 Share Posted January 11, 2021 Would be neat if RR gives him -2 to damage. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5652939 Share on other sites More sharing options...
Wolf Lord Loki Posted January 12, 2021 Share Posted January 12, 2021 I wonder if revoltingly resilient might be a damage cap? Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5652999 Share on other sites More sharing options...
Balerion84 Posted January 12, 2021 Share Posted January 12, 2021 I wonder if revoltingly resilient might be a damage cap?Definitely not. How would it work when both Mortarion and for example Plaguecaster can have it? It won't be able to be based on fixed amount of dmg obviously and writing a rule that'd be based around % when you could put it on models with 5 or 18W wouldn't work. The obvious guess would be -2D since it used make DR better. But it could be something completely different. I'd put my cent on the -2D per attack personally, but we'll see. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5653053 Share on other sites More sharing options...
Lord Raven 19 Posted January 12, 2021 Share Posted January 12, 2021 Revoltingly resilient may be a fnp? Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5653065 Share on other sites More sharing options...
Marshal Loss Posted January 12, 2021 Share Posted January 12, 2021 Revoltingly resilient may be a fnp? Maybe, but I'd expect it to function similar to how it does now (a modification of DR) as Balerion posits above Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5653077 Share on other sites More sharing options...
techsoldaten Posted January 13, 2021 Author Share Posted January 13, 2021 I'm thinking there will be a psychic power or two that offers additional buffs on top of all this. Either way, if Mortarion can now stay in the battle past turn 3, he's going to be a force in a game that relies on controlling objectives. Used strategically, he could just be tying up part of an opponent's army for a few turns while Poxbringers seize objectives. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5653354 Share on other sites More sharing options...
Special Officer Doofy Posted January 13, 2021 Share Posted January 13, 2021 Mortarion will be a turd to bring down if revolting resilient reduces the damage by another 1. I can't wait to use him again. I just hope he doesn't become the opposite of what he was. I don't want him to be so over powered that no one wants to play against him. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5653375 Share on other sites More sharing options...
Plague _Lord Posted January 14, 2021 Share Posted January 14, 2021 I'm guessing its a 6+ FnP Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5653634 Share on other sites More sharing options...
techsoldaten Posted January 14, 2021 Author Share Posted January 14, 2021 Mortarion will be a turd to bring down if revolting resilient reduces the damage by another 1. I can't wait to use him again. I just hope he doesn't become the opposite of what he was. I don't want him to be so over powered that no one wants to play against him. My guess is RR and DR will work by decreasing the save and adding to the roll. Together that would be a +2 to the natural save roll, or a 33% chance of shrugging off the damage (just like the old FNP.) That plus 9 ablative wounds from bodyguards that get passed after a fail - I don't see how he can reliably be taken down in a 5 turn game. The odds of causing a wound would be very, very low. And this is all before psychic powers have been applied. Will find out Saturday how tough he is. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5653948 Share on other sites More sharing options...
Iron Sage Posted January 15, 2021 Share Posted January 15, 2021 I'm guessing its a 6+ FnP Confirmed to be the old 5+ FNP, so much better ! Basically, most of the DG warlord traits in the new leaks seem better than previously, they even improved Arch Contaminator. Edit: They didn't improve Arch Contaminator, they nerfed it in utility but made it help with plague short range shooting. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5654210 Share on other sites More sharing options...
Balerion84 Posted January 15, 2021 Share Posted January 15, 2021 Really glad Morty keeps MW protection. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5654216 Share on other sites More sharing options...
techsoldaten Posted January 16, 2021 Author Share Posted January 16, 2021 Mortarion will be a turd to bring down if revolting resilient reduces the damage by another 1. I can't wait to use him again. I just hope he doesn't become the opposite of what he was. I don't want him to be so over powered that no one wants to play against him. Your worst dreams may have just come true. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5654349 Share on other sites More sharing options...
Marshal Loss Posted January 16, 2021 Share Posted January 16, 2021 So, the good news for this topic: Mortarion is incredible. The bad news for this topic: Deathshroud no longer protect him. :P Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5654482 Share on other sites More sharing options...
techsoldaten Posted January 17, 2021 Author Share Posted January 17, 2021 I'm honestly not sure Deathshroud make a difference. It's going to take a lot of anti-tank weaponry to hurt Mortarion. Mathemathically, it takes an average of 700+ bolter shots to put him down. Most armies aren't capable of that in a game. Mortal wound spam - maybe Grey Knights can pull that off, but there's not that many ways to do that many wounds before he gets to you. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5654962 Share on other sites More sharing options...
Bulwyf Posted January 19, 2021 Share Posted January 19, 2021 Morty in 8th was so bad I couldn't bring him to games even friendly games. Now he's so good my regular opponents don't want to play against him. Unreal. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5655474 Share on other sites More sharing options...
techsoldaten Posted January 19, 2021 Author Share Posted January 19, 2021 Morty in 8th was so bad I couldn't bring him to games even friendly games. Now he's so good my regular opponents don't want to play against him. Unreal. That’s frustrating. It’s the paradox you never want; a model is garbage and nobody plays it or a model is “overpowered” and people complain about it and refuse to play against it til it’s nerfed to being unusable again. I hope they aren’t marine players refusing to play you; they shouldn’t have anything to complain about lol. To be fair, writing the rules for a Primarch has to be tough. No direct comparison with any other unit in the game. Once Magnus came out, I was using him every other game until he was no longer useful. He could solo other armies at 1k points, then one day he was FAQed. Mortarion's rules are insanely good. I expect them to be insanely bad soon enough. Sad more people are not playing in my area. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5655647 Share on other sites More sharing options...
Bulwyf Posted January 19, 2021 Share Posted January 19, 2021 Morty in 8th was so bad I couldn't bring him to games even friendly games. Now he's so good my regular opponents don't want to play against him. Unreal. That’s frustrating. It’s the paradox you never want; a model is garbage and nobody plays it or a model is “overpowered” and people complain about it and refuse to play against it til it’s nerfed to being unusable again. I hope they aren’t marine players refusing to play you; they shouldn’t have anything to complain about lol. They are. Especially the one guy that gave up his Black Legion to come back to be a Salamander successor picking the best units and cheese he can find. He thinks Morty is too OP to have "fun" games against. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5655673 Share on other sites More sharing options...
Iron Sage Posted January 19, 2021 Share Posted January 19, 2021 Morty in 8th was so bad I couldn't bring him to games even friendly games. Now he's so good my regular opponents don't want to play against him. Unreal. That’s frustrating. It’s the paradox you never want; a model is garbage and nobody plays it or a model is “overpowered” and people complain about it and refuse to play against it til it’s nerfed to being unusable again. I hope they aren’t marine players refusing to play you; they shouldn’t have anything to complain about lol. They are. Especially the one guy that gave up his Black Legion to come back to be a Salamander successor picking the best units and cheese he can find. He thinks Morty is too OP to have "fun" games against. Ugh. What great self awareness he has. You have my sympathy on playing that guy. It doesn't sound like a cool opponent at all. Link to comment https://bolterandchainsword.com/topic/368496-mortarion-and-deathshroud/#findComment-5655701 Share on other sites More sharing options...
